Internally wired bar problems
Old Jan 15, 2013 | 01:38 PM
kennygsuperglide's Avatar
kennygsuperglide
the wire mesh seems like a fantastic idea. wish I would have thought of that before I did mine. I'm considering tearing it apart just to ad the mesh Great Idea , cary , everyone should use it.
Old Jan 16, 2013 | 10:03 AM
HDCustomFabrication's Avatar
HDCustomFabrication
This is a real issue if you do not use any kind of "conduit" to protect the wires inside the bars. Any bar that is welded may have sharp points inside at the joints, it only takes one to ruin your day.
Either wire mesh or the soft tubing, which is what we use, will work perfectly.
When we install wires we install them at the same time as the tubing and push/pull the tubing not the wire. By pushing as you pull it should easily go around any corner. Give it more push than pull and you will not have any problems.
Bochawa72
Jan 12, 2019 05:38 PM
Randy La Rose
Mar 22, 2016 10:01 AM
CrazyHog
Dec 10, 2013 10:18 AM
randayn
Jan 5, 2012 06:36 AM
AmmoHouse
Jul 15, 2011 07:59 PM
