Handle bar installation
Old Mar 20, 2016 | 08:33 AM
Randy La Rose's Avatar
Randy La Rose
6th Gear
Default Handle bar installation
Just installed new 14" bars I went to put on the clutch and brake controls and there isn't a recess for the external wiring like on the original bars any suggestions besides internally wiring them I'd like to leave them externally wired thanks any suggestions appreciated.
Old Mar 20, 2016 | 08:46 AM
decencyxdefied's Avatar
decencyxdefied
Y are you opting for external wiring?
Old Mar 20, 2016 | 08:55 AM
Randy La Rose
6th Gear
It was suggested by the mechanic that I deal with in case there's problems it's an easier fix..
Old Mar 21, 2016 | 10:21 PM
scooper321's Avatar
scooper321
I don't understand that response from a quality mechanic. I soldered my own wire extensions and ran the internally. Yes, I would have to take apart the bars if there's a problem. But it's a few wires. Point A to Point B. What sort of problem is he afraid of? Maybe you should get another opinion from a second mechanic.
Old Mar 21, 2016 | 11:49 PM
Jackpot Johnnie's Avatar
Jackpot Johnnie
I'd keep next Saturday open and pull the new bars and run the wires internally. In the long run you will be much better off then grinding a notch in your controls for the external wires.
Old Mar 22, 2016 | 12:04 AM
crimson13's Avatar
crimson13
+1 , I did the same. I do not understand why any mechanic would suggest to keep the wires external.
Old Mar 22, 2016 | 05:20 AM
Randy La Rose
6th Gear
Thanks for all your responses I guess in the past he has seen problems with the Tbw and was trying to save me some bs down the road.. There isn't a lot of room on the right side for all the wires is there.
Old Mar 22, 2016 | 05:43 AM
Rustrtal's Avatar
Rustrtal
HD Part #32310-08 is the Screaming Eagle Twist Grip Sensor that doesn't have the green plug and is longer. I just bought one from Surdyke for $85.
Old Mar 22, 2016 | 08:44 AM
grbrown's Avatar
grbrown
Internal wiring and extending wires can be a problem, which pops up regularly around HDF. It's not something I personally would tackle, but I'm surprised that Randy went into this without being prepared. Either buy notched bars for external wires, or set out to wire internally!
Old Mar 22, 2016 | 09:35 AM
scooper321's Avatar
scooper321
Fair point. My bike is not TBW and I've heard that routing the wires through handle bars on bikes that are TBW is sometimes a bit of a pain. But it's also commonplace. As said above, there are lots of threads on this topic. This is where I came to learn what I was getting into when I did it.
