SE compensator
Old Jan 14, 2013 | 08:31 PM
69onmy09dyna's Avatar
69onmy09dyna
Default SE compensator
I there a difference between the 40274-08 and the 40274-08A? Ive got an 09 FXDC and have seen the -08 on ebay but want to make sure there is not a superseded part with the new number. Thanks
Old Jan 14, 2013 | 09:06 PM
Junkster's Avatar
Junkster
There must be or there wouldn't be a different part number. Theres an old thread out here about this. Something about a washer i think. I take it your looking at doing it huh? I just put the 40274-08A on my Dyna last week. Havent been able to ride as really cold here around Omaha huh?
Old Jan 15, 2013 | 09:02 AM
69onmy09dyna
Im doing it. Have a starter noise but didnt sound exactly like the comp noise I read about so I took primary cover off to inspect. Started drive and "flywheel" teeth look great so has to be comp. Now just need to buy. I used sixth gear and rear brake to hold everything to remove clutch nut and comp bolt. You know dimensions of the locking bar? Your in Omaha? This weather freaking sucks!!! Road all last year!
Old Jan 15, 2013 | 10:42 AM
thedonthere's Avatar
thedonthere
locking bar is 7" easy enough to make
Old Jan 15, 2013 | 06:57 PM
Jacoblb's Avatar
Jacoblb
I used an old ratchet I had.
Old Jan 16, 2013 | 08:08 PM
Junkster's Avatar
Junkster
Yes I'm north of CB. Yes I put on 1k a month last year all the way thru winter. Not this year. Damn roller coaster weather. Gonna ride friday suppose to be 51. I used a 7" piece of 2x4. Worked great. I didnt remove clutch basket. I stroked the case a little removing a little aluminum. Didnt want to mess with inner case leaks. If you dont have the 1"3/4 wrench they sell them at Tractor Supply for 21$ or a pipe wrench would probably work.
Old Jan 23, 2013 | 11:17 AM
69onmy09dyna
FYI, I did find out about the number change. I changed only because HD added more bikes, models, etc. The part is the same! Just got mine off ebay for 175.00 plus 15 shipping! 250.00 new. WOOFREAKNINHOO!! Doing the 30000 mile service too. Anybody know what grease to use for the steering head bearings? Says special purpose grease in the manual. WTF? Junkster- thanks for the imput and love riding your neck of the woods. beautiful area.
Old Jan 23, 2013 | 11:51 AM
Jacoblb's Avatar
Jacoblb
I use Mobil 1 grease on everything bearings. Thats what I use in my truck and its worked great.
Old Jan 23, 2013 | 12:38 PM
NSCoyote's Avatar
NSCoyote
i keep a tub of this stuff on hand for bearings
http://www.lucasoil.com/products/dis...d=307&loc=show
Old Jan 23, 2013 | 09:27 PM
Junkster's Avatar
Junkster
Anytime man. Yea the scenic routes around here aint too bad. Need more twisties though. You got a good price on the comp sprock. Surdyke Harley in Festus, Mo has good pricing on new if you cant find something your looking for on ebay. I paid 219 new. I like marine grade grease. It's special ya know
