Switchback front brake lever fade
Old Jun 2, 2014 | 12:05 PM
heavyd1's Avatar
heavyd1
I haven't had that, but I am noticing some seepage around the rubber gasket, I tightened it up som but I don't think it really helped. It does have decent pressure though
Old Jun 3, 2014 | 10:43 AM
the_cruz's Avatar
the_cruz
I had the same problem. Brake would fade over night, then I started noticing the fluid was leaking... I went to the dealership and bought a new cover and gasket... Swapped it myself and haven't had a problem since. I think part of the issue is people over thinking the problem. The other part is people over tightening the cover. Keep a real close eye on the gasket as your tighten the cover, if you see it start to pinch it is too tight and will leak.
Old Jun 3, 2014 | 10:42 PM
johnnyo883's Avatar
johnnyo883
I had the same problem, but the dealer replaced the master cylinder under warranty and the front brakes are now very solid.
skos
Mar 28, 2020 09:58 PM
Thumper26
Oct 28, 2015 11:17 AM
challutz
Aug 25, 2010 09:06 PM
JustDave71
May 21, 2010 11:10 PM
HilllBillly
May 5, 2010 03:47 AM
