Any suggestions? Im not sure if i like the HD kit cuz of how far it sticks out...if anyone has pics of them or others on your scoot that would be great...thanks
Check out the Joker Machine LED signals on the tubes below my headlight. They are small yet visible. I have mine turned outward slightly but the can set flush to the lower tree
I got these stand-off triple tree replacement bolts from a dude on eBay. They're great, if you're keeping your stock signals and should work with other bullet-type signals. The signals are in as close as possible to the triple tree.
I like those joker LED's, didn't even know what to look for in SLV's pic heh.
Since we are pretty much invisible on the road, I'm thinking about just removing my front ones or else I'll get the jokers, very low profile.
With the problems yall are having with the light flashing fast on the console, would that be an issue with JUST the joker leds?
Depends on the bike. '12 and '13s will have the issue but its easy to fix with a 3 ohm resistor inline with the power wire. You'll already be splicing, so the resistor is a 5 minute add on step.
Some of the '11 and earlier models work without the resistor.
Here's a close-up when they were still flush with the lower horizontal on the tree. They rotate easily with an Allen wrench. You do have to slide the tubes out to install them.
