If you use a different caliper and rotor, you will eliminate your abs. I'd change pads and brake lines, too. But what problems are you experiencing. A few here have had master cylinder problems from new and got replacements.
Thanks for the info, I dont want to eliminate my ABS.
The problem I am having is just a lack of braking power and I really have to pull on that lever very hard.
How will I know if I have a master cylinder problem?
I'd go by the dealer. That doesn't sound right. It could be air or the master cylinder. You can try the fix I read the other day. Tie the lever down over night. That can help the air issue. It won't help the master cylinder.
Yes, if the brakes don't improve in the next few hundred miles I will definitely go by the dealer and get them to check it out.
