The crank position sensor (CKP) is about $50-$60 ... at least when I had to replace mine about 5 years ago I seem to recall it being $54 ...
I kind of doubt the CKP is causing your problem ... is it possible, I suppose ... you might remove it and inspect it ... maybe put a micrometer to it to test it ... (don't know what the readings are supposed to be, though) ...
I tend to think that it might have either something to do with your ECM / PC (tuner) ... or possibly something to do with ignition system (coil, plug wires) ...
I think you're being a little sensitive to the suggestion to unplug the Power Commander and try that ... if it is bad (or a bad connection, etc) ... you should be able to tell by removing it temporarily ...
I don't think it has anything to do with your starter ... I presume you would have been able to tell if your starter was not engaging (starter clutch) or if it was grinding enough to mess up the pinion gear or (clutch basket) ring gear teeth ...
Since the fuel pressure was tested I don't think that is an issue (if you had a hole in the in-tank fuel line, the symptom would be cutting out when your fuel level was low) ...
That leads me to believe that the program that feeds fuel is causing the problem ... which points me toward your PC (or possibly your ECM) ...
Also, if your plug wires are shot (no longer provide proper resistance) I am thinking it could cause an issue ... or if the coil were not providing the proper current/voltage to the plugs ... could cause hard starting ...
I am leaning towards PC/ECM because of your poor fuel economy ...
Good luck and be sure to post follow up when you get to the bottom of it ...
I'm also guessing its the power commander, I would never have a piggy back tuner for that reason. Did you wash the bike or ride in the rain about the same time the problem started?
I would think the Harley dealer would have tested the CKP but I guess not.
It could be the power commander but I just want them to put some effort into it and tell me what the problem is. If it's the Power Commander then fine but don't just guess, damn I could do that.
I just lost a lot of confidence in them when they wanted to blame the battery because it wasn't a genuine Harley battery and then tried to send the bike out the door.
What is odd is that the bike when it starts seems to run fine.
If I get it back and they don't fix it (I am betting that's what is going to happen) then do I just unplug the Power Commander and then try to start it? Or do I need to plug anything back in it's place?
This problem has been going on for a long time, about a year I believe so it has seen a few wash jobs.
Is it throwing any codes?
If it isn't I would also agree with the PC or ecm.
These 2 will not throw a code but the CKP will.
You get no warning most of the time when the CPK goes out. If you do get a warning it will miss like crazy or go in and out. I had no hard starts, it either started or it wouldn't.
I just lost a lot of confidence in them when they wanted to blame the battery because it wasn't a genuine Harley battery and then tried to send it out the door.
You need to plug the O2 sensors back in or you are gonna get a code. They should have eliminators plugged in now. You will be fine running it a while like that. The non factory certified parts thing is typical to ALL types of dealers. I had a Jeep once that was making a bad noise in the front end. Ran me crazy trying to find it. Finally took it in. The dealer's diagnosis: Aftermarket brake pads...They kindly offered to change them for a not so small fee...It ended up being a defective sway bar...There was a recall on it to...*** clowns...
What was stupid is they tested the battery on their new super fancy battery tester they said they just got in and it would take 30 minutes because it does all kinds of tests. That was this past Sunday and they said it passed fine so they suggested I bring the bike in and then when I do they say the battery isn't a Harley battery so that's probably it.
It is good advise to unplug the PC and try again! I have never ran across a PC that was worth bringing home anyway. My son had two different PC's and they were both problematic. Just NOT a PC advocate. I know they can cause more problems than they solve. Just my take on them anyway...good luck and keep us posted!
That could do it ... (i.e., reloading the map) ...
I had an episode where my bike was running like crap one night after work ... I pulled over, did a reset on the ECM (ThunderMax w/ AutoTune) and started back up ... ran like a top ...
