fat spoke spacer help
Old Mar 3, 2013 | 07:51 PM
beaudaciousb's Avatar
beaudaciousb
they are too wide however i ordered a set that had a bunch of different sized for about 30 bucks im just lost as to how do i figure what spacing i need so the wheel is centered etc etc ive done almost all the work on my bike and i love it but this is something thats out of my comfort zone even though it basic if somebody showed me id be golden.
Old Mar 4, 2013 | 03:33 AM
beaudaciousb
ok this might paint a better picture......
1. the axle width in between the swing-arms is 10.5
2. the hub width is 7.5
3. there is about 2.5 offset from where the spokes are on the pulley side and a 1.25 on the right with the brake rotor
4. also the brake caliper bracket is 1.25
what i need to figure out is where to center the wheel and what spacers to use on the left side and on the right in between the rotor and brake caliper bracket.... now the middle of the axle would be 5.25 and the middle of the hub would be 3.625...... so you would assume that's where both centers need to line up and then you would simple measure the space on either side fab spacers to fit and be happy.......
however if ya that leaves very little room on the left ive seen a thread where they milled down the brake cailper bracket 5mm and sacrificed a goat or something and everything was good im just lost
Attached Thumbnails fat spoke spacer help-imag0142.jpg   fat spoke spacer help-imag0145.jpg   fat spoke spacer help-imag0149.jpg   fat spoke spacer help-imag0152.jpg   fat spoke spacer help-imag0154.jpg
jp-1
Apr 16, 2020 05:06 AM
spankdog
Jul 3, 2012 09:59 PM
wtf6316
Jan 3, 2011 09:09 PM
gjantzer
Dec 21, 2009 01:17 PM
motorcycle mikey
Jun 24, 2008 04:27 PM
