vin # decal
Old Feb 10, 2007 | 05:57 PM
74c10sb's Avatar
74c10sb
Default vin # decal
has anyone removed the vin # decal on the right down tube of the frame ? is it legal to do so?
Old Feb 10, 2007 | 06:20 PM
Snydcat's Avatar
Snydcat
Default RE: vin # decal
I don't know if it's legal or not but I took all mine off the downtube.
Old Feb 10, 2007 | 06:34 PM
lolife's Avatar
lolife
It is ugly...........just in a bad spot..................thought about puling mine off from day one....................havnt..............Is it legal.................Good question....................LO....
Old Feb 10, 2007 | 07:21 PM
jmbear328's Avatar
jmbear328
Even though it is stamped into the frame neck and on the engine,... I would consider it to be the VIN stamp and that, YES,...it would be illeagl to remove the label.
John
Old Feb 10, 2007 | 08:19 PM
NEONNIGHT34609's Avatar
NEONNIGHT34609
I think it would be ok to remove it .. i mean what if u powder coated the frame the label would be removed then .they have stamped #s on the neck for years i think this is where most if not all cops know where to look for them.a sticker is a sticker its notgonna last forever . i have been thinking about mine and removing it also
Old Feb 10, 2007 | 08:31 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Federal law requires all vehicle manufacturers vin tags to be visible and unaltered. Any police officer can impound your bike on the spot of the vin tag has been removed or altered. Better not touch it. You will have a hard time selling or trading the bike in without it.
Old Feb 10, 2007 | 08:58 PM
pococj's Avatar
pococj
The tag always gets messed up sooner or later. Yank it off and don't worry about it. The number stamped in the frame is the one that counts.
Old Feb 10, 2007 | 09:07 PM
but Ill try 2 try's Avatar
but Ill try 2 try
Aren't there 2 stickers on there in that same spot. I pulled off one of mine a while back, but left the VIN sticker.
Old Feb 10, 2007 | 09:59 PM
mwdguy's Avatar
mwdguy
what about covering it in some decal material the same colour as your downtube, then if it's needed you can pull the vinyl off?
Old Feb 10, 2007 | 10:23 PM
NEONNIGHT34609
good luck with that have u ever tryed to take a sticker off a sticker ???
ORIGINAL: mwdguy
