2000 dyna
Old Feb 18, 2013 | 04:06 PM
hdloride69's Avatar
hdloride69
Stage I
Question 2000 dyna
Good afternoon everyone,New guy here with a question on twin cam fluids..
Since my nearest dealer is an hour away i'm trying to find out what the equivelent of the transmission and primary fluids the manual says to use..any ideas?? We just purchased this 2000 Dyna Low Rider with 19,000 mile and dont know when or if they have ever been changed. Thank's Scott
Old Feb 18, 2013 | 08:56 PM
scoriden's Avatar
scoriden
Oil with new filter - 2.5 Quarts (Wet) or 3.0 Quarts (Dry change)
Trans - 20-24 oz
Primary – Fill to bottom edge of clutch diaphragm spring, Aprox 26oz
This info is right out of the Service Manual which you should buy right away – best money you can spend. Without one, be sure to research here. Very common mistake to drain the wrong plug.
Also you will need new gaskets and O rings, the dealer can help you with this.
Here is a pix I got from Ron750 here, it is part of the oil thread.
Congrats on the new scoot and good luck!
Old Feb 18, 2013 | 09:06 PM
Good_Apollo's Avatar
Good_Apollo
You can use 20w50 in all three holes if you want.
I use 20w50 in the engine and trans, and 75w-90 gear oil in the trans
90FLHS
Dec 29, 2013 03:27 PM
straightleg
Feb 21, 2011 07:42 PM
SE120RG
Jul 13, 2010 08:12 PM
jett78
Oil Archive (no new posts)
Mar 28, 2008 02:07 PM
YellowHawk
Nov 23, 2007 12:09 AM
