tire size question
Old Feb 26, 2013 | 12:01 PM
SkyWalker's Avatar
SkyWalker
6th Gear
Default tire size question
I have an 03 superglide with stock rim and tire, I was wondering if anyone knew how big a tire I can put on it without changing anything. Thanks
Old Feb 26, 2013 | 12:38 PM
Shrug's Avatar
Shrug
I always refer to this chart...
http://www.hdwheels.com/Product.htm
Old Feb 26, 2013 | 09:07 PM
SkyWalker's Avatar
SkyWalker
6th Gear
Thanks that is very helpful
Old Feb 26, 2013 | 09:59 PM
Danofxdx's Avatar
Danofxdx
I put a 160mm Metzler ME880 on my 2001 FXDXT Stock is a 150mm
Old Feb 26, 2013 | 10:03 PM
Otang's Avatar
Otang
I suggest proceeding with caution. I put a 21" front wheel on my 07 fatboy and now need to change fender mount as the wheel hits the underside of fender. The chart says it would fit.
Old Feb 27, 2013 | 02:25 AM
OldTyme's Avatar
OldTyme
I agree with Otang. According to that "chart" my 01 FXDL standard rear tire is 150/80 when I believe standard is 130/90. I'm sure a 150 has no problem fitting, but I think a 160/60 might be a tight fit.
Old Feb 27, 2013 | 06:08 AM
NSCoyote's Avatar
NSCoyote
any mods you had to do to get a 160 up i nthere?
Old Feb 27, 2013 | 06:32 AM
ynots's Avatar
ynots
something to consider is some tire brands vary in their width. A Dunlop K591 - 160/70-17 is visibly wider than a Michelin Scorcher the same size 160/70-17
Old Feb 27, 2013 | 09:07 AM
SkyWalker's Avatar
SkyWalker
6th Gear
Thank you everybody for your input I will have to check more of this info out safe riding
Old Feb 27, 2013 | 09:50 AM
Hogpro's Avatar
Hogpro
Former Sponsor
You can do an 18x4.25 with a 160 on your bike on the back. On the front a 21. I did a 21x2.15 on my 02 Dyna but I have seen plenty with the 21x3.25 or 21x3.5. With the wider rim the tire will be extremely close to the fender brackets if not touching so that is something to consider.
