Exhaust wrap recommendations
Old Mar 4, 2013 | 11:48 AM
Shrug's Avatar
Shrug
Originally Posted by Dynam1te
Wrap from back, to front.
+1 Dynamite! Every wrap and how-to video I've seen was front to back, exposing the leading edge to wind and rain.
Another tip: If your exhaust has frame mounted brackets that the wrap will be on both sides of, clearly mark the location and orientation of the brackets on the pipes before you remove them. If you get things wrapped up tight and the alignment is off, you're screwed when you try to reinstall.
Old Mar 4, 2013 | 11:52 AM
Dynam1te's Avatar
Dynam1te
Glad someone else recognizes this. I see so many crappy wrapped pipes because they wrapped front to back. If you plan on actually keeping the wrap for a while and want it to look nice, do it right the first time.
Back to the front.
Old Mar 4, 2013 | 12:14 PM
MXerwithaBob's Avatar
MXerwithaBob
I will also add, if I had to do it again, I would double wrap my pipes. That would mean starting at the front to rear back to front. The pipes/wrap get super-hot, so hot that I can't keep my foot down for very long.
Old Mar 6, 2013 | 12:43 PM
osb's Avatar
osb
I bought the DEI kit recently and it came with 2 15' rolls. This was recommended by V&H and DEI as enough to wrap my pipes..I have serious doubts.
I have the V&H 2->2 Big Radius, I plan on removing at least the upper heatshield..
Old Mar 6, 2013 | 02:05 PM
Shrug's Avatar
Shrug
One 50 foot roll covered my straight shots front to back and they're pretty long. You might make it with 30 feet.
Old Mar 7, 2013 | 06:27 AM
osb's Avatar
osb
Thanks Shrug. I'll get around to it at some point this week..supposed to be raining and snowing for the next two days.
Old Jun 4, 2013 | 03:30 AM
seethesvt's Avatar
seethesvt
How bout a white wrap? Fucl black, I want white..
Old Jun 4, 2013 | 07:05 AM
Good_Apollo's Avatar
Good_Apollo
DEI titanium does not need to be soaked to use, and it is easy on the hands, no need for gloves.
Old Jun 4, 2013 | 01:18 PM
Shrug's Avatar
Shrug
True dat, Apollo. I found a killer deal on some Short Shots and wrapped them in titanium. The process was much easier than the other wrap and it looks great.
Old Jun 5, 2013 | 01:29 PM
CombatMedic's Avatar
CombatMedic
+1 for DEI...the only way to go. The titanium was much easier to work with, but it really depends on your color preference.
-J
