Chrome wheels rust
Old Mar 10, 2013 | 01:04 PM
dirtdobber's Avatar
dirtdobber
surface rust is very common on spoke wheels in the location you mentioned. Chrome cast wheels will do the same but differently.
What you are seeing is a lack of maintenance, chrome requires maintenance. Cleaning is a maintenance when it comes to chrome.
I do detail at times for folks. chrome spoke wheels can be a pain if not cleaned properly and often enough. you can go to walmart in the paint department and get some 0000 steel wool. It will clean the rust off and not scratch the chrome. Smaller parts are difficult to chrome entirely. Proper timely cleaning will eliminate this. This is one of the reasons I do not have bikes with spokes. Flats is the main reason. They have tubes.
The wide glide in my signature is my wifes
Old Mar 10, 2013 | 01:11 PM
macnab_sf's Avatar
macnab_sf
aluminum foil and water - scrub the rust off.
then keep them coated with wd40, or better - Gibbs
[At some point, you decide to spend the money for stainless]
Old Mar 10, 2013 | 01:26 PM
03geetee's Avatar
03geetee
SOS pads, some water, and some beer and a good weekend will get you the results you want. Did mine after I bought her, still working on it, but looking good.
**** powdercoat.
JTR
Old Mar 10, 2013 | 07:43 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
What happened to good ole elbow grease and a little maintenance. There is a myriad of products out there to take care of rust on chrome. While you are on your bended knee maybe you will see a loose bolt or something else that needs looking after.
MIRoadKing65
Mar 1, 2018 08:38 PM
HOGNIT
Apr 3, 2012 10:32 PM
antman27
Oct 28, 2009 01:43 PM
masterblaster
Oct 8, 2008 03:15 AM
KBFXDLI
Apr 14, 2007 07:45 PM
