Wobble
Old Mar 31, 2013 | 01:58 AM
sgmfiser's Avatar
sgmfiser
Too many beers, that's what make them wobble. In the wind.
Pops
Old Mar 31, 2013 | 12:01 PM
davidearlcox's Avatar
davidearlcox
Originally Posted by gartec81
Rear swingarm is connected to your tranny. So it has some play.
I checked my FXDC factory service manual on the swing arm and it doesn't mention side to side movement specs, least so far as I've found. But I don't think there should be any appreciable side to side play there if the bushings are good, bushing cups and spacers are all there and the pivot shaft nut is torqued to spec (70-77 ft-lbs).
The only things I can see that would cause rear wheel wobble be a loose swing arm or bad wheel bearings. I did see other threads posted about bad wheel bearings on some of the low mileage Dynas.
Old Mar 31, 2013 | 01:42 PM
Junkster's Avatar
Junkster
Loose spokes could cause this. On either rim. Do a ting tang test. My bike has had high speed wobble twice. I finally figured out it was the throw over bags I was using.
Old Apr 1, 2013 | 04:21 PM
tattoowho's Avatar
tattoowho
M
y front spoke make sing, but the rear ones don't . They appear to be touching in the center.
Old Apr 1, 2013 | 06:08 PM
lo-rider's Avatar
lo-rider
OP--You just keep ignoring the advice to CHECK YOUR TIRE PRESSURE !
Old Apr 1, 2013 | 07:01 PM
Jonesee's Avatar
Jonesee
Easiest thing in the world to check:
Take one hand off the handlebars. If the wobble stops you are gripping the bars too tight.
(you won't admit it, but I bet you a beer that is what you learn) The wind makes it more noticeable.
If it still wobbles:
start with air pressure
look for unusual wear on tire
look for the sign of a wheel weight that has been thrown
then work your way up the forks.
Within 30 minutes you will know what is causing it.
Old Apr 1, 2013 | 07:10 PM
Wild Card's Avatar
Wild Card
The only time I have ever had any of my bikes wobble was due to a death grip. Whether it be from being scared to death, fearing of death or running from death.
Old Apr 2, 2013 | 05:00 PM
tattoowho's Avatar
tattoowho
I didn't ignore that. I check the tire pressure. All good, the front was down by 3 pounds, but I suspect that wasn't enough to cause a problem. BUT THANKS ANYWAY.
Old Apr 2, 2013 | 06:01 PM
Junkster's Avatar
Junkster
+1 on that. Seems crazy but it's true.
JekyllnHyde
Oct 28, 2016 11:13 PM
the_skin_eater
Aug 28, 2013 07:11 AM
GAZippoman
"The Georgia Crew"
21
Mar 2, 2013 12:10 PM
doc_cj
Dec 28, 2007 03:32 PM
Fearless1
May 29, 2007 08:25 PM
