Superbrace - Installed
Old Feb 15, 2007 | 08:44 PM
scarab75's Avatar
scarab75
Default Superbrace - Installed
I ordered a Superbrace during the last group buy and put it on a few days ago. Nice piece, fully polished, great fit and I actually noticed a difference. Bumps and turns feel more in tune, freeway speeds you can feel the bike square up not bouncing to the left or right.
[IMG]local://upfiles/16263/92DA863D77FF4B4CAA6681685B594353.jpg[/IMG]
Old Feb 15, 2007 | 08:54 PM
hd_sob's Avatar
hd_sob
Default RE: Superbrace - Installed
Did you install them as recommended (with the front end off the ground)? Just checked their website ans didn't see anything in a 49mm. Whats the part number? THANKS!
Old Feb 15, 2007 | 08:56 PM
metal_mike's Avatar
metal_mike
ORIGINAL: hd_sob
use the part # for the vrod.....should be the same [49mm.]
Old Feb 15, 2007 | 08:59 PM
hd_sob's Avatar
hd_sob
Their website only lists H-D models up to 2005. I guess its too much trouble for them to update it.
Old Feb 15, 2007 | 09:04 PM
scarab75's Avatar
scarab75
PN # 5191GB - all 2006 dyna except wide glide (they are making one soon).
Per there instructions I just put a 2x4 under the kickstand to get the bike close to level and loosened the axle pinch bolts and put the brace on and re torqued the pinch bolts. I didn't read anywhere that the front end had to be off the ground (don't see why it would have to be???). Nice and quick install.
Old Feb 15, 2007 | 09:09 PM
hd_sob's Avatar
hd_sob
Looks like they changed their recommendation, although loosening the bolts apparently accomplishes the same thing. I talked to them awhile back and they told me to lift it off the ground. The reason I asked is because I have read that some people followed that advice and some just slapped them on there. Never did determine if it made a difference either way. Looks good, maybe I'll still get some after everything else on my list...
Old Feb 15, 2007 | 09:16 PM
glideridemike's Avatar
glideridemike
Any more group buys on the super brace for us?
Old Feb 16, 2007 | 02:36 PM
Marlon's Avatar
Marlon
Are you sure it fits for a Street Bob if I buy the V Rod model? It looks great.
Old Feb 16, 2007 | 02:58 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
ORIGINAL: scarab75
What size are your axle pinch bolts?
Old Feb 16, 2007 | 05:02 PM
rh8234's Avatar
rh8234
Does anyone know if the superbrace will fit with chrome fork lowers? The HD fork braces do not because the chrome plating adds a few thousandths to the diameter of the fork lower.
