Front wheel bearings for 2003 fxdl removal and replace
Old Apr 10, 2013 | 02:42 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Here's a nice video on the use of the HD bearing remover/installer:
Old Apr 10, 2013 | 04:51 PM
razors edge's Avatar
razors edge
I have an 09 dyna fxdc. Is it the exzatc same i don't know. I tried the blind hole pulled and it failed to budge the bearing. I wound up grindind a short 3/4" pipe to just fit inside the ID of bearing and weld it to make a shoulder that i could take a long punch and drive the bearing out. Hopfully your will come out easier. Then i went to a local bearing store for replacement bearings. Was able to buy domestic bearings way cheaper than the HD dealer wanted.
Old Apr 11, 2013 | 07:22 AM
03Custom883's Avatar
03Custom883
just bought the tool from amazon so i will be doing this as soon as my bearings and tool get here thanks guys
Old Apr 24, 2013 | 05:41 AM
03Custom883
Did the bearings last night using that tool. Worked very well
Cleaned everything regreased the axel used antiseeze when installing the new bearings everything torqued to spec. Should be good to go. Should be able to test ride it today or this weekend.
Thanks guys
DavidStiebel
May 6, 2016 06:32 PM
hardheaded
Feb 27, 2013 07:34 PM
kdodd
Jun 14, 2012 11:48 AM
roofer
Jul 26, 2010 08:45 AM
2007fxdc
Wheels/Tires
Jan 15, 2009 12:40 PM
