07 SB Electrical Problems! Help!!
Old Apr 10, 2013 | 06:46 PM
ResidentPirate's Avatar
ResidentPirate
Originally Posted by jimsflh
follow both cables from the battery and make sure they are tight on both ends
10-4 thanks for the tip!
Old Apr 11, 2013 | 06:58 AM
McGinnes_john's Avatar
McGinnes_john
It also will usually work better to tighten the cables with a ratchet or wrench (10mm, if I remeber) than a screwdriver. The soft metal will strip easliy. A torque wrench is even better (80 inch pounds).
Old Apr 11, 2013 | 10:06 AM
ResidentPirate
Gave the bike a once-over last night, checked my battery connections, they're good & tight, but in tracing the ground to the engine I did indeed find that the ground was loose! Pulled the ground, cleaned up the connections, used some anti-seize as previously recommended, and took her for a spin... no issues at all. Rode into work today, no issues. I think I'll take the recommendation of another forum member and use lock washers on my battery terminals instead of the standard washers I'm using now. Thanks everyone for your input - one of these days I'll have some useful tips for some of you!
Old Apr 11, 2013 | 10:23 AM
JRK5892's Avatar
JRK5892
great news!
Old Apr 11, 2013 | 11:22 AM
ResidentPirate
Originally Posted by JRK5892
great news!
yes indeed! Hey Joe, happened to see your posts on The Dyna Page! Stoked to hear that your stereos are selling well to that group of guys!!
Newgene
Jun 16, 2023 07:36 AM
Bluesrider
Jun 7, 2023 09:38 AM
BROWNS-RUSS
Jul 22, 2013 02:50 PM
mike06train
Jul 6, 2011 10:36 PM
Nevar
Dec 1, 2007 05:53 AM
