Hard start
Old Apr 15, 2013 | 07:29 PM
calminiboxer's Avatar
calminiboxer
4th Gear
Default Hard start
I have a 2010 FXDWG that cranks and backfires and sounds like it is going to rip the starter off the bike after a hot soak. If I ride 5 miles and stop to fill up this thing kicks and grinds and makes you wonder if you're walking home. If the bike is cold or sits for a hour or more it starts great. I have checked and cleaned battery cables and ends, tried a new coil, disassembled the starter and couldn't see any problems. Any help would be greatly appreciated.
Old Apr 15, 2013 | 07:47 PM
Northbound Southerner's Avatar
How old is the battery?
Old Apr 15, 2013 | 08:07 PM
target64's Avatar
target64
you might want to look at the crank sensor
Old Apr 16, 2013 | 12:51 PM
calminiboxer
4th Gear
i pulled it there are no cracks and tests perfect according to the shop manual.
Old Apr 16, 2013 | 04:44 PM
target64's Avatar
target64
what do you have for a tuner on it? does it spin over slow like you have a lot of compression ?
Old Apr 16, 2013 | 05:03 PM
bobnehoc's Avatar
bobnehoc
Not sure if this is the same problem but when I stop for gas or something my 07 grinds occasionaly when I try to start. This only happens when it is hot like after a ride and I shutdown and try and restart a few minutes later......Grinding noises happens.....bad starter clutch. I will be replacing mine with a new one from AllBalls.....
Old Apr 16, 2013 | 05:14 PM
Koonass31's Avatar
Koonass31
I would like to know if anbody knows as well i have the same issue. My bike was doin it before i put my tuner on it and still does after. I have a screaming eagle fuel tuner
Old Apr 16, 2013 | 05:25 PM
Jackie Paper's Avatar
Jackie Paper
Is it stock? If not, what has been done? How many miles on it? Get it to what produces the problem and before you crank it, screw the plugs out and see if they are wet. You may have an injector leaking. Worth checking since it's simple to do.
Old Apr 16, 2013 | 07:06 PM
calminiboxer
4th Gear
I hooked a fuel PSI gauge on it holds 62PSI hot and cold and cranking. It has vance hines pipes stage 1 download from harley and highflow air filter. It started at 35k and has gotten slowly worse now has 68k and getting very embarrassing. the battery and stater is new and charges great.
Old Apr 16, 2013 | 07:39 PM
Puffdaddy's Avatar
Puffdaddy
I had read in a thread as a trick for those having this problem (myself included), and it has worked for me.
If the bike is hot from recent riding, don't wait for the fuel injectors to prime before starting. Flip on the ignition and IMMEDIATELY hit the start button. I have been doing this for the better part of a year and the bike starts more easily.
Might as well give it a try, since it is free. If it doesn't work, you get what you pay for
