PCV Issues
Old May 10, 2013 | 08:01 PM
hd4evr2008's Avatar
hd4evr2008
I take my bike to a shop that has three very, very experienced Harley mechanics. I'd bet that between the three they have over 100 years of experience. One of them builds Harley Davidson XR750 race engines for top Grand National flat track racers. Those engines are about $15,000 apiece. He KNOWS what he's talking about when it comes to Harley engines. NONE of them................I repeat................NONE of them has anything good to say about Power Commanders. As one of them said when I took my bike in for the EXACT same problem you're having "Get that Power Commander OFF your bike!!" He was right. As soon as he took it off, my bike ran fine again. I wouldn't give you three cents for a Power Commander.
Old May 10, 2013 | 09:02 PM
dmpjr's Avatar
dmpjr
So you are not using a tuner at all? I may go that route
Old May 10, 2013 | 09:18 PM
hd4evr2008's Avatar
hd4evr2008
Well, I went with the simple dealer download and my bike runs great with just that.
Old May 10, 2013 | 09:33 PM
harley7316's Avatar
harley7316
I had a power comander was a big pain in the but using a fuel pak set it once and bike is running fine.Just wondering your bike was running fine why did you go with pc?Were you going to cams etc?I would do what the previous poster said zero out you map and if the bike runs fine its you map if it doesnt run fine then you may have a bad pc.Good luck hope you get it figured out.Miss the old days of a carb easy to tune no injectors map sensors etc
Old May 10, 2013 | 09:36 PM
dmpjr's Avatar
dmpjr
I am planning on cams in the future..now I'm a little hesitant to do anything. The bike used to be fun to ride.. Now it runs like ****..... Runs fine without the pc--I think I pissed $300 out the window.
Old May 10, 2013 | 09:41 PM
harley7316's Avatar
harley7316
Well unless you want to spend the money getting a dyno sell it and if it ride fine dont worry about till you do some more mods.I know some dudes on here rag on fuel pak but i set it once and bike runs great so i can complain but i hear on pc never had luck with it but i know alot on here swear they are the best.Just take it out and ride if it runs fine done need it anyways
Old May 11, 2013 | 01:52 AM
covman454's Avatar
covman454
6th Gear
I had issues when I installed Big Radius 2-2 with my PCV. Finally after talking to Keith several times and two new map updates (always richer), I found the problem to be that I had left the baffles in the pipes when I installed them. My 12 WG was having a serious hesitation/cutting out problem. I removed the baffles and that made all the difference and now it seems to be running great. Minor backfiring when I really twist it up and let off. If I have anymore problems, I will drop an autotune in it.
Covman
Old May 11, 2013 | 06:06 AM
maddghost's Avatar
maddghost
No man, someone will fix you up. At the very worse FM will cut you a deal on an upgrade or lateral trade for another tuner. I don't think they would have sold you the pc-v if it wasn't good for your bike. I know it must feel like your in a washing machine, if you call dynojet they will kick you back to FM but it is worth a try. I've been there and done that , but with patience it'll work out. It does suck that this is happening to you.
Old May 14, 2013 | 01:12 PM
dmpjr's Avatar
dmpjr
Well, I just tried a zero map and most of my issue are gone. The hesitation is completely gone, I do get some decel popping if I make it happen. That proves to me that tuners are way over-rated. I bet I get my fuel economy back also.
Old May 14, 2013 | 01:53 PM
latrobedyna's Avatar
latrobedyna
If it was me, I simply just get the SERT from HD and be done with it. I tried they power commander myself and what a paice of s&%t never did work right. Luckily some guy wanted it worse them me and well i want did the Sert never looked back
