won't rev past 5k
Old May 14, 2013 | 05:31 PM
joshpg3412's Avatar
joshpg3412
Default won't rev past 5k
oi vey. someone please help me.
i recently ditched my thunderheader and installed a supertrapp supermeg. i continued to use the custom tune loaded onto my power commander v, which was created on a dyno at an indie shop. it ran fine, if a little rich.
suddenly, the bike won't rev past 5k rpm, and starts getting really rough around 4,800. this was way below the stock rev limiter. it would previously hit 65k using the rev xtend feature. it seems to run fine up until that point.
i called dynojet today. i updated my firmware, reloaded the map with rev xtend enabled, changed the plugs, checked the oil, and checked for exhaust leaks, all to no avail. any ideas?
Old May 14, 2013 | 05:32 PM
joshpg3412's Avatar
joshpg3412
also no codes that i know of. at least they're not showing on my dakota digital gauge.
Old May 14, 2013 | 05:43 PM
bloodweiser's Avatar
bloodweiser
exhaust leak?
Old May 14, 2013 | 05:49 PM
joshpg3412's Avatar
joshpg3412
i checked. don't seem to have, but i may have missed it. also, would an exhaust leak really cause the bike to just crap the bed at a particular rpm?
i've been doing some research and i'm wondering if it's the crank position sensor. anybody have any experience with that?
Old May 14, 2013 | 06:04 PM
maddghost's Avatar
maddghost
Check your throttle position on the pc-v! get the bike warmed up, you need to hook up a computer to the pc-v. select power commander tools-> calibrate->throttle position with the throttle off turn ignition on and run switch on, click reset. open throttle fully and release, click ok, your done. It may work. All the info you need is in http://www.powercommander.com/powerc..._PC5.1.19.html can be done with engine running or not as long as you turn on the ign. and run
Old May 14, 2013 | 06:39 PM
GaugeMods's Avatar
GaugeMods
Former Sponsor
I always thought that the PCV tricked the ECM to rev to 6200 and the tach still showed that it only rev'd to 5200.
I have the stage1 download and the PCV and when I activated the Rev Extend my tach only showed 5200 but it was still going to 6200 in my Innovate Technologies LM2 Data Logger. I kept bouncing off the rev limiter trying to get to 6200 or at least the tach to 6200. It doesn't take much time from 5200 to 6200
Old May 14, 2013 | 07:07 PM
joshpg3412's Avatar
joshpg3412
i have a dakota digital and it shows the proper rpm.
Old May 15, 2013 | 02:13 AM
tsport117's Avatar
tsport117
I've seen that happen with a broken valve spring. If your reving to 6500 often and your springs aren't up to the task, it's something to consider. If the inner spring is broke, the outer spring keeps things in check until you hit about 4.5-5k then it'll start sputtering (floating) like it hit the limiter.
Easy to lift your rocker covers for a peak.
Old May 23, 2013 | 05:48 AM
joshpg3412's Avatar
joshpg3412
looks like it was the power commander. the bike runs fine stock. i spent some time on the phone with dynojet the other day. after some attempted troubleshooting, they requested that i send it back to them. i'll update with anything further.
therick04pp
Nov 1, 2019 09:48 PM
ib5150
Apr 6, 2013 11:39 AM
Doug Bearden
May 31, 2012 07:21 PM
usefulshrimp
Aug 17, 2011 11:24 AM
Stanger
Apr 29, 2008 12:34 PM
