bottom mount headlight on super glide
Old May 29, 2013 | 04:52 PM
sparks427's Avatar
sparks427
Default bottom mount headlight on super glide
Has anybody ever drilled a hole to allow for a bottom mount headlight on a stock super glide lower tree? I know by taking it off the top id have the big ugly cutout part in the upper tree. But i was curious if it had been done. Thanks
Old May 29, 2013 | 05:01 PM
Robtarra39's Avatar
Robtarra39
Yes this has been done many many times, and is a very easy task to perform, as for the ugly opening left after the headlight brow is removed, just look at the sportster customs then have a nice trim piece that covers the upper tree opening very nicely
Old May 29, 2013 | 06:10 PM
sparks427's Avatar
sparks427
Ok cool, thanks for the info, i found a cover piece at jp cycles, it has the ind. Lights slot in it tho so i may check around for a cheaper one. And i found a headlight i think im gunna use. Is there anything i need to do with the groove on the bottom side of the tree?
Old May 29, 2013 | 06:45 PM
dirtdobber's Avatar
dirtdobber
I will be doing it as soon as I get my bike back.
Old May 29, 2013 | 07:10 PM
sparks427's Avatar
sparks427
Sweet, i think im gunna wait till this winter to do it so my bike isnt tore down durring the riddin season. I plan on doin some other stuff then too.
Old May 29, 2013 | 10:22 PM
snstiggy's Avatar
snstiggy
I did mine as mentioned above. Took about 20 min. Great mod and it was easy.
Old May 29, 2013 | 10:36 PM
sparks427's Avatar
sparks427
Snstiggy-- what did you do on the bottom of the tree where the groove is at? Anything imparticular?
Old May 30, 2013 | 09:31 AM
Shrug's Avatar
Shrug
I removed the stock headlight and drilled the top clamp from beneath. I then cut a small piece of metal (1"x2") and drilled a hole on each end for mounting to the clamp and replacement light. I put heat shrink on it and mounted the light. The pic below is before I cleaned it up.
I used the holes in the top clamp that the stock headlight mounted on to mount the indicator bar. The cut out in the top clamp is invisible unless you look for it. It provides a nice gap for the wires to the speedo and tach.
Old May 30, 2013 | 11:01 AM
wisemx's Avatar
wisemx
Awesome work there.
Old May 30, 2013 | 04:44 PM
sparks427's Avatar
sparks427
Thats awsome shrug! What kinda bars are those?
