What else?
Old Jun 9, 2013 | 02:01 PM
WideGlideFever's Avatar
WideGlideFever
Default What else?
Hey fellas, putting together a took kit (see pic) for a long road trip, what else do you suggest I put in there. Off the top of my head I am thinking spare spark plugs. I am also going to get a 3/8 to 1/4 adapter for the smaller allen and torx sockets.
Appreciate your thoughts and inputs.
Old Jun 9, 2013 | 02:52 PM
jpicht's Avatar
jpicht
Default tools
I would add some channel locks, cresent wrench, and electrical tape. And maybe a tire patch kit.
Old Jun 9, 2013 | 02:56 PM
dirtdobber's Avatar
dirtdobber
I make my own to.
The only metric you need is a 10mm.
I use a screwdriver with assorted bits.
Only 3 torx and 6 allens. I use a shaving kit bag with 2 zippers.
the new new style pliers that grip like a wrench. Flat tire kit, but you have spokes.
Extra bulbs, and throw away die electric grease packs.
!/4 inch drive ratchet and 3/8 adapter.
A lot in the small package.
Old Jun 9, 2013 | 02:59 PM
WideGlideFever
no patching here, got tubes... good idea on a couple of adjustable wrenches and electrical tape!
Old Jun 9, 2013 | 03:04 PM
WideGlideFever
Originally Posted by dirtdobber
I make my own to.
What is the 10mm used for? I thought about using 1/4" primarily and having an adapter for 3/8, but I think I am more comfortable with it the opposite way.
I do have an extra bulb, but I need to get some grease.
Are the 3 torx and 6 allen the most common ones or the only ones that you will ever need? I am not sure what I would need so thats why I planned on bringing all of them.
I guess I should mention to, that in addition to a long road trip, I wont be coming back home for about 3 years, so I would like to take what I would use while I am gone for routine stuff.
Old Jun 9, 2013 | 04:20 PM
FXDWG12's Avatar
FXDWG12
Ok now I see the need for tools. That's a long road trip.
Old Jun 9, 2013 | 04:23 PM
rooti's Avatar
rooti
Never ever forget the duck tape, a small flashlight, and extra fuses and bulbs
Old Jun 9, 2013 | 04:46 PM
cee's Avatar
cee
I usually have a piece of tubing for siphoning, draining if I need. Tywraps, tape, small adjustable wrench or pipe wrench.
Old Jun 9, 2013 | 05:24 PM
SquidHead's Avatar
SquidHead
A good knife.
Old Jun 9, 2013 | 05:26 PM
shorelasHD's Avatar
shorelasHD
It's said that ANYTHING can be fixed with WD-40 and duct tape. If it should move, and it doesn't, use the WD-40. If it shouldn't move, and it DOES, use the duct tape...
