Well, I am finally finished my Dyna project...this took a lot longer than I had expected but it was a learning experience. As soon as the snow melts I can get a couple betterpics outside.
ORIGINAL: Night_Train01
It started out as a 1987 Dyna custom frame. It had 38° rake and I added 6° chrome wide glide trees and 6" over forks. I kept the original 4 speed trans, Iwent with a horseshoe oil tank which also holds the battery. The frame has 2" of stretch, this allowed me to use a longer tank. I always liked the look of the bobbed fender so this is what I choose for this bike. The engine is a Revtech 110", I had major issues because the largest starter I could get to fit the 4 speed was a 1.4. The 1.4 on its own will not turn the motor over, I added the kick, this way I can kick the engine past the compression stroke and the bike will fire right up. I live in Ontario Canada so I had all winter to put the bike together, I did my own paint and I had the seat custom made . This is my first V-Twin project, I stripped the bike down to the frame and pretty much started from scratch. Here is a pic of what I started with in my basement.....
Very nice job.
How's it handle??
The before picture adds another dimension to the story.
Mud, I have no idea how it handles......I am waiting for the snow to melt to take the bike on her maiden voyage
Pretty much the only thing I kept from the original bike was the frame, the trans and the back wheel. Everything else was either bent, stripped or cracked. I knew that I wanted a big engine so I had the frame sandblasted and some gussets welded in to add strength. I just hope the trans works....its a lot of work just to find out I need a new transmission. If it does not work properly then I will put in a 5 speed, at least then I can get a larger starter to turn the engine over.
Hope things work out well Train.
A 5 or 6 speed may be a big plus.
Here in South Texas, I rode today w/o jacket.
Don't know how you guys do it up there in the frozen North.
