New Pipe & Scraping Issues
Old Jun 17, 2013 | 02:25 PM
ResidentPirate's Avatar
ResidentPirate
Default New Pipe & Scraping Issues
Installed a Bassani RRII this weekend, and loving the pipe - except that it runs a bit low, and my bike was already lowered when I installed it. To counteract potential drag on the new low pipe, I removed the lowering links from the rear shocks, which raised it up about an inch - but now what to do about the front end? I'm not really in a position to put in new springs, ricors, etc, so I'm thinking about simply cutting new spacers at an additional 1.5" to give me the necessary clearance. Questions are:
1) Do the spacers sit at the top of the forks or the bottom?
2) What material is best to cut the spacers out of?
3) Could it really be as simple as adding longer spacers???
Old Jun 17, 2013 | 02:28 PM
rooti's Avatar
rooti
I think most of your scraping will only be helped by adding taller shocks. You can add additional spacers in the front end but I don't think it will really help.
Some people are running 13 and 13 1/2" shocks on their dyna
Old Jun 17, 2013 | 03:48 PM
ResidentPirate
I neglected to mention that the bike has a progressive drop-in lowering kit, and I'm scraping on the bottom-most bend - in fact, the scrape is only on that bend, so I'm hoping that lifting the front end will make enough of a difference to avoid most scraping. Definitely considering taller shocks, but if I go that route I think I'll need to rework the entire front end. Really looking for a band-aid at the moment...
Old Jun 17, 2013 | 04:51 PM
SLV's Avatar
SLV
Top
PVC
Yes.
On an airplane and gotta go.
Old Jun 17, 2013 | 05:02 PM
ResidentPirate
Originally Posted by SLV
Top
PVC
Yes.
Thanks brother! BTW I recently followed you on SoundCloud... ShockProof!!! Killer stuff my man!
Old Jun 17, 2013 | 05:22 PM
rooti's Avatar
rooti
If you don't need it to be lowered then post in the WTB classifieds and see if someone still has their stock front springs that you could buy next to nothing. Also make sure your back shocks are on it's hardest setting.
Old Jun 17, 2013 | 05:36 PM
ResidentPirate
Good idea! I'm going to post it up right now!
Old Jun 17, 2013 | 07:24 PM
emerican19's Avatar
emerican19
I'm not too familiar with how the Bassani attaches, but generally raising the rear doesn't give your exhaust more clearance. It spaces the fender from the tire, but everything revolves around the swing arm, which still would be at the same angle from the ground.
Old Jun 17, 2013 | 08:44 PM
SLV's Avatar
SLV
Hey! Thanks a lot. I didn't realize that was you. Got any six string ideas for the song? I'm alright on bass but can't play guitar to save my life.
http://soundcloud.com/slv-2/shockproof/s-GmeG4
Here's one of my finished songs. I wish I knew a guitarist with some consistent ideas. This guy kicks *** but isn't available often.
http://soundcloud.com/slv-2/city-girl/s-di4k4
Old Jun 19, 2013 | 10:19 AM
ResidentPirate
hmm I'd need to give it a few listens to get a vibe, but the drum track lends itself to some real variety... I'll think on it!
Definitely diggin City Girl!
