Triple trees removal question.
Old Jul 5, 2013 | 02:07 PM
Reaper_ggy's Avatar
Reaper_ggy
Default Triple trees removal question.
Fxdwg 2010
I'm removing the trees to powder coat them.
Iwant to know the torque spec of the neck bolt when mounting back
and if i'm only removing the trees is in necessery to mess with the bearings in there ?
Old Jul 5, 2013 | 03:59 PM
Bo_Jangles's Avatar
Bo_Jangles
Get a shop manual. They are a cheap investment. The neck bearing on the bottom tree is a pain to remove from the stem. The stem is pressed into the tree itself.
Old Jul 6, 2013 | 09:09 AM
Reaper_ggy's Avatar
Reaper_ggy
I've just found one buts kinda weak :
STEERING HEAD 2.18
REMOVAL
1. Remove fork sides. See 2.17 FRONT FORK.
2. Remove the headlamp from lower fork bracket. See
8.9 HEADLAMP.
3. See Figure 2-89. Remove the fork stem cap (1). Remove
the fork stem nut and the handlebar with upper bracket
(4). Be careful not to pinch or kink control cables.
4. Remove the adjusting nut (5) and pull the fork stem and
bracket (12) out of the steering head. Remove the upper
dust shield (6) and bearing cone (7). Slide fork stem (12)
and bracket (13) from frame.
INSPECTION
1. Check upper and lower bearing races in steering head. If
they are pitted or grooved, replace the bearings and races
in sets.
2-58 2008 Dyna Service: Chassis
Replace both bearing assemblies even if one assembly
appeares to be good. Mismatched bearings can lead to
excessive wear and premature replacement. (00532b)
2. Check the roughness of the bearings by turning them in
the race. Replace bearings if they do not turn freely and
smoothly.
DISASSEMBLY
PART NUMBER TOOL NAME
HD-33416 UNIVERSAL DRIVER
STEERING HEAD BEARING RACE
REMOVER
HD-39301-A
sm02275
1. Remover (2 pieces)
2. Collet
3. Driver
Figure 2-90. Race Remover Tools
Steering Head Bearing Race Removal
1. See Figure 2-91. With the tapered side down, seat the
two-piece STEERING HEAD BEARING RACE
REMOVER (Part No. HD-39301-A) (1) on the upper
bearing race leaving a gap in the middle.
2. Install the collet (2) on the UNIVERSAL DRIVER (Part
No. HD-33416).
3. Insert the driver at the bottom of the steering head tube,
and while holding the remover tool on the race, center the
collet in the gap (3). Tap the driver to remove the upper
race.
4. Reverse the tool and repeat the procedure (4) to remove
the lower bearing race.
NOTE
If bearing cups are removed, the bearings cannot be reused.
They must be replaced. The lower bearing cone is not pressed
on fork stem and may be slipped off fork stem along with lower
dust shield.
1. See Figure 2-89. Insert the stem and bracket assembly
into the frame steering head and install the upper bearing
(7) and dust shield (6). Secure with the adjusting nut (5).
Tighten the adjusting nut until there is no noticeable shake
or freeplay between bearings and races. Fork stem must
turn freely from side to side.
NOTE
The washer under the fork stem nut is a special hardened
material. Never replace this washer with a common flat washer.
Doing so may allow the fork stem nut torque to loosen resulting
in loss of steering control.
2. Install upper bracket (4), hardened flat washer (2).
NOTE
Original equipment fork stem nut has a blue coating. If a
new nut is being installed, the replacement nut will not
have a coating.
Whenever the stem nut is loosened or removed, the
threads must be lubricated with anti-seize lubricant prior
to assembly and tightening.
3. Lubricate threads of fork stem nut (3) with a light coating
of anti-seize lubricant. Install stem nut and tighten securely.
4. Install the headlamp assembly. See 8.9 HEADLAMP.
5. Install fork sides. See 2.17 FRONT FORK.
6. Adjust steering head bearings. See 1.20 STEERING HEAD
BEARINGS.
7. Tighten fork stem nut to 70-80 ft-lbs (94.9-108.4 Nm).
8. Install the fork stem cap.
9. Align headlamp. See 1.23 HEADLAMP ALIGNMENT.
Thats all I got on the subject, they say the replace the bearings if theyre rough ... But what I wanna know is if I got to pull them out to remove the trees ?
Old Jul 6, 2013 | 12:39 PM
f3fidy's Avatar
f3fidy
+1 on getting the shop manual -
DYANA MODELS 2010 Harley Davidson service manual
part number 99481-10
If I understand what you are asking, when you remove the lower fork bracket (lower triple tree) the bearing cone will come with it. One of them at least. For me the second one fell out of the upper tree. I kept the bearing cones in a zip lock bag and reinstalled them later. They only had 2300 miles on them.
As for the Fork stem nut, this is torqued to 70-80 ft-lbs or 95-108.5 Nm ONLY after you have set the Fall Away. See manual for correct procedure or do a search here.
Please double check my numbers by getting the manual. Section 1.21 Steering Head Bearings page 1-41.
I used a plumb-bob tapped to the ceiling of my garage.
Old Jul 7, 2013 | 04:06 PM
Reaper_ggy's Avatar
Reaper_ggy
i got the part number 99481-08 should be the sae from 06-11 i think no ?
ADJUSTMENT
HD-41494 HUBCAP REMOVER AND INSTALLER
Bearing Adjustment (Fall Away)
1. Support motorcycle in an upright position so the front end
is completely suspended and the vehicle is level.
2. Remove all accessory weight, such as a windshield, that
may influence the way the front end swings. If clutch cable
is routed so it pulls the front end one way or the other,
disconnect it.
3. Place a suitable marking material, such as masking tape,
over the fender tip.
4. Install a pointer so the base is stationary on the floor and
the pointer indicates the center of the fender. The front
end should be straight ahead, however the balance point
may be slightly off center.
5. Check steering head bearing tension.
a. Tap the fender on one side until the front end begins
to "fall-away" by itself. Label this point on the marking
material.
b. Repeat the previous step in the other direction.
c. Measure distance between marks.
6. The distance between the "fall-away" marks must be 2.0-
4.0 in (50.8-101.6 mm).
NOTES
If distance measured is 2.0-4.0 in. (50.8-101.6 mm) no
bearing adjustment is needed.
If distance measured is outside the range given, bearing
7. See Figure 1-45. With HUBCAP REMOVER AND
INSTALLER (Part No. HD-41494) unscrew and remove
stem cap (3).
8. Loosen fork stem nut (5).
9. Loosen lower triple clamp pinch bolts.
sm02477
1. Star nut
2. Upper triple clamp
3. Stem cap
4. Hardened flat washer
5. Stem nut
6. Pinch bolt (2)
Figure 1-45. Steering Head Components
10. Tighten or loosen the star nut (1) until the measurement
is within limits.
a. If the distance is more than 4.0 in. (101.6 mm), turn
the adjuster nut counter clockwise to loosen.
b. If the distance is less than 2.0 in. (50.8 mm), turn the
adjuster nut clockwise to tighten.
11. Remove the stem nut and lightly lubricate the threads with
12. Install stem nut and tighten to 70-80 ft-lbs (95-108.5 Nm).
13. Check fall-away. If it is 2.0-4.0 in. (50.8-101.6 mm), tighten
lower triple clamp pinch bolts to 30-35 ft-lbs (40.7-47.5
Nm).
14. Repeat the "fall-away" procedure to be sure the adjustment
is correct.
15. Install and adjust clutch cable.
16. Test ride motorcycle.
LUBRICATION
Use SPECIAL PURPOSE GREASE (Part No. 99857-97) every
30,000 mile (48,280 km) service interval. For steering head
bearing lubrication, see 2.18 STEERING HEAD.
2008 Dyna
I'm might be too dumb to understand but you put the weight to take a measuring point on the fender when the bike is completely lifted right ? Then the 2 to 4 inch measurement is when you put the bike back on the ground ? or still lifted you ``tap`` to make it go all the way down
Old Jul 7, 2013 | 09:51 PM
f3fidy's Avatar
f3fidy
No worries. I didn't explain my pics that I posted. So I dropped the plumb-bob down and it should not touch the fender. Find center on your fender and mark with a sharpie and piece of tape. My pics are before sharpie mark. Oh ya the front end should be lifted. And follow the procedure from there.
PM me if you run into any issues.
Old Jul 8, 2013 | 07:34 AM
Reaper_ggy's Avatar
Reaper_ggy
Not youre fault i understand that step, in the manual they say to tap it after, thats where im kinda lost in the explanation, the 2 to 4 inch variation from start to when you tap youre fork under it goes all the way down ?
FXD2003Rider
Feb 11, 2025 07:57 PM
one4classix
Touring Parts
Oct 4, 2019 07:44 AM
skully1200
Jul 11, 2012 10:24 AM
SCHOONER
Wheels/Tires
Mar 15, 2011 12:35 PM
DR. V-TWIN
Sep 6, 2010 10:17 PM
