2013 FXDB tail relocation... not from Harley
Old Jul 6, 2013 | 09:11 PM
203Cree's Avatar
203Cree
Default 2013 FXDB tail relocation... not from Harley
So when I got the bike, I knew I'd be faced with having to come up with something creative when it came time to put the wife on the back. I absolutely loath the relocation kit Harley wants those of us with 13's to use, and I didn't want rigid plates either, as it's a solo bike more often than not. So, here's what me and a buddy of mine came up with.....
Now, that looks pretty simple, but there's a couple things to note here.
First, the original bullets are threaded for 5/16, and the mounting hardware and the wires share separate holes in the stock standoff's.
The detachable hardware kit requires 3/8's bolts front and rear for the bushings.
Long story short, we took 2.5 inch, 3/8 x 16 bolts and drilled 9/64'th holes thru them, then drilled and tapped some front bullets (the rears are contoured differently for the stand offs) for 3/8's. Add in the HD side mount plate kit for the 12's and older and there it is. The cheapest? No. Easiest? Huh, if you've ever dried to drill thru a grade 5 bolt length wise with a cordless drill, then you should know that no, it wasn't easy. But, I think it looks pretty dang good on there.
Old Jul 6, 2013 | 09:59 PM
dirtdobber's Avatar
dirtdobber
cool
I love checking out things us diy make.
I make a lot of my own stuff to. Very rewarding and you get it your way.
bigbadpoppa
Apr 5, 2016 12:44 PM
Greg Di
Jan 8, 2013 02:32 PM
cary713
Sep 6, 2010 10:47 AM
jbhawley
Jul 17, 2009 07:28 AM
shakak
Sep 11, 2008 11:52 AM
