2012 front turn signal relocation
Old Jul 14, 2013 | 06:38 PM
Dyna7's Avatar
Dyna7
Default 2012 front turn signal relocation
Ok so I finally decided to relocate the front signals to the forks on my 2012 street bob.
I cut the wires from the controls, yanked down the wiring harness, downloaded the harley instructions for their kit, looked once, looked twice, and looked another million times and I am still lost.
There are two connectors down their, the black connector and the white connector, that are not connected to anything. From how I understand the instructions I am supposed to hook my turn signals up to those, now my question for yall is, does the harley kit come with those two male connects (pn - 73153-96bk) or are there two more connectors up there that I dont see that I am supposed to hook my turn signals up to then connect them to the other connectors?
Thanks for all the help, there is a reason I did not become an electrician....should have called the father in law...well....no im better off asking yall
Old Jul 14, 2013 | 06:58 PM
10ovr's Avatar
10ovr
On my 2013 bob the pig tails for the turn signals were about 8" farther down the harness from where the control wires plug in ,,Also do you have the right kit ??
Old Jul 14, 2013 | 07:03 PM
Dyna7's Avatar
Dyna7
I dont have the hd kit, just the instructions for the 2012 kit.
By the pig tails, do you mean the ones that run all the way up into the turn signals themselves?
Old Jul 14, 2013 | 07:10 PM
10ovr's Avatar
10ovr
Where the control harness connected in the back bone of the frame under the tank,,Like I said,,My bike is a 2013,,May be different then a 2012,,Mite have to wait for someone with a 2012 to clue in,,
Old Jul 14, 2013 | 07:29 PM
Dyna7's Avatar
Dyna7
yea, thats where the connectors are, but i had to cut my signals from the housings, i am wondering if there are two sets of connectors down there to use
Old Jul 14, 2013 | 07:48 PM
10ovr's Avatar
10ovr
Yes there is an extra set of plugs about 8" or so down the harness ,,Pull the harness out farther ,,There is a lot of harness in there,,
Old Jul 14, 2013 | 07:59 PM
TX Rebel's Avatar
TX Rebel
The last page of the instruction sheet has the contents of the kit, and yes it shows them in the kit.
Old Jul 14, 2013 | 08:24 PM
Dyna7's Avatar
Dyna7
can you show me which one you are looking at, because I dont see it on mine
Old Jul 14, 2013 | 08:48 PM
HD Pilot's Avatar
HD Pilot
With the HD kit, you get new wires to run from the relocated turn signals to the white and black connectors you have already found. Yes, the HD kit includes molex terminals that you install/crimp on the 3 individual wires from each turn signal, and these terminals are inserted into a new connecter(again part of the kit) that connects to the connectors you have found.
Now since you are not using the HD kit, I would probably cut off the connectors you have found and hard wire or solder the wires together that run from the relocated turn signals. I am assuming that you have new wire to run from the turn signals.
Hope this helps a little.
Old Jul 14, 2013 | 09:01 PM
Dyna7's Avatar
Dyna7
That answers the question, thank you!
I ordered the connectors already, and yes I already have wire ready to go for the signals.
Thanks for the answer and all the replies everyone!
