VHT on Exhaust Shield
Old Jul 15, 2013 | 03:39 PM
StFrancis's Avatar
StFrancis
Default VHT on Exhaust Shield
The Previous Owners black powdercoat job on my exhaust shields/covers is starting to flake off. Im thinking of using the VHT to wrinkle black them to match everything else on my bike (07 street bob) Wondering if anyone has used this on the exhaust covers before and if they used the VHT primer as well... I would think one can of each would be enough but I might do my derby cover as well...Thanks!
Old Jul 15, 2013 | 04:28 PM
macnab_sf's Avatar
macnab_sf
What's the temp rating on the wrinkle black?
Old Jul 15, 2013 | 04:43 PM
HYPR's Avatar
HYPR
I have used VHT on heat sheilds with great results. But WARNING be sure to use the VHT for Headers which is good to 1200 degrees while the engine version is only good to 500 degrees.
Proper application and heat cycling is the key to a durable finish.
You will need to do a recoat after a year or two since it will be prone to chips and some fading.
Bob
Old Jul 15, 2013 | 06:26 PM
HD Bobber's Avatar
HD Bobber
Why not just repowder them? Powder will cost a bit more but look a lot better and last longer.
Old Jul 15, 2013 | 06:45 PM
fxdxharley's Avatar
fxdxharley
my shield are heat paint and it didnt last. wears off fast. i would have have them repowdered. stay away from the wrinkle on pipes it will burn off, not ment for heat over 400 deg.
Old Jul 15, 2013 | 07:38 PM
Antonio Balls's Avatar
Antonio Balls
Default Ceramic Coatings
Go to this website: www.jet-hot.com. This is ceramic coating which will keep the pipes cooler and will last. They come in various colors but black and polished are probably the most popular. My brother in law owns five bikes (Dukati and BMW) and routinely sends every header pipe to them. Cost is reasonable ( $100 for two pipes) and the work will last. Use the series 1300 coating for bike headers. Largest selection of colors.
ringer1969
2014-2024 Touring Models
18
Apr 13, 2019 04:38 PM
Road Star
Powdercoat & Paint
Mar 19, 2015 08:04 AM
HedleyLamarr
Exhaust System Topics
Aug 6, 2012 07:16 PM
JBrowning
Jul 2, 2012 07:05 PM
peddler
Mar 2, 2009 06:59 PM
