Need help! Tail light removal? Fat Bob
Old 07-20-2013, 08:57 PM
toku58's Avatar
toku58
toku58 is offline
Default Need help! Tail light removal? Fat Bob
I have all the lights off, but the housing doesn't budge? Are the blinker mounting bolts the only ones holding the unit?
Is there a trick to getting this out? I don't wanna just tug and pry at it if at all possible.
Any help would be greatly appreciated!
Old 07-20-2013, 10:15 PM
HD Pilot's Avatar
HD Pilot
HD Pilot is offline
Hey toku58, I am away from my HD Service Manual, but if my memory serves me right the rear light housing is held in by a bracket on the inside of the fender. To loosen the bracket you have to loosen the fender rails with the red reflectors, then you can loosen/remove the 2 brackets. Hope I remember OK - on the road right now.
Hope those Rush slip-ons are doing well!
Old 07-20-2013, 11:07 PM
Flight Risk 103's Avatar
Flight Risk 103
Flight Risk 103 is offline
Remove the torx head bolts that secure the chrome strut covers and behind them you'll see two nuts which hold each bracket Alan referred to, inside the fender. After removing the nuts, you can push the threaded studs (which are part of the bracket) thru the fender and remove the bracket. Then the tail light can be removed.
Installed a tri bar tail light on mine a couple of weeks ago, so this is still pretty fresh in my memory. In two more weeks I probably won't remember any of it lol.
Old 07-21-2013, 12:57 AM
toku58's Avatar
toku58
toku58 is offline
Thanks for the reply! I actually figured it out after looking at it for a while. I'll post up pictures of how things turned out in another thread!
Mahalo!
Tower
01-29-2019 03:32 PM
Saguaro
Milwaukee Eight (M8)
04-25-2017 06:46 PM
case013
08-12-2014 06:58 PM
GregH
06-07-2012 01:23 PM
IceMan1
General Topics/Tech Tips
09-12-2011 10:56 AM
Quick Reply: Need help! Tail light removal? Fat Bob
