Jury riggin' the main fuse...
Old Jul 22, 2013 | 03:08 PM
FXD_noob's Avatar
FXD_noob
Default Jury riggin' the main fuse...
This little trick helped me get back home. The fuse has been changed now, but there's an electrical issue nonetheless.
Old Jul 22, 2013 | 03:36 PM
Gommee's Avatar
Gommee
Devil's Advocate
When stranded, that will get you back on the road. Done that a few times on several vehicles in the past.
It would be a good thing to figure out why it blew before you did that so that it does not fry the rest of your system when you jump it and it has no way to blow again.
I keep a spare one of those fuses in my tool pouch.
Old Jul 22, 2013 | 04:06 PM
FXD_noob's Avatar
FXD_noob
Definitely! I just rebuilt it with the help of friends (I had an accident on February, and we just put it back together) so the problem could be anywhere...any ideas on where to start checking? I think I'll make a thread about it later this week and pick on all your brains.
Old Jul 22, 2013 | 04:13 PM
Gommee's Avatar
Gommee
Devil's Advocate
I would tend to think you have a short. What happened or what were you doing just before it popped?
Signal, brake (front or rear), high beam, hit bump or tracks, hard braking, tight corner? If you can narrow down the just before, it will help find root cause.
Also, that is your main fuse, so check your battery connections first.
Old Jul 22, 2013 | 05:14 PM
Robbie13's Avatar
Robbie13
LOSER
The fuse is in place to protect your wires/components from getting too much current. If you ride with the makeshift wire for too long...it will show itself in the form of melted insulation or fried components. Would definitely check for a short to ground. If it is intermittent, makes it that much tougher to find. Good luck.
diablo75
Jul 7, 2025 02:19 PM
07SCBOB
Mar 4, 2016 09:23 PM
07SCBOB
Electrical/Lighting/Alarm
Mar 4, 2016 04:07 PM
vbboatcop
Aug 14, 2014 05:50 PM
tmac00333
General Topics/Tech Tips
Oct 10, 2011 06:39 AM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
