Need help installing fairing
Old Aug 11, 2013 | 12:38 PM
605bob's Avatar
605bob
Originally Posted by dmoe0826
Maybe throw up a few pics of where it's going too...might be able to look at both and get it figured out for you
I mounted the bracket to the cowl. Placed the cowl in front of the headlight to mock up the appearance. It leaves the mounting bracket BELOW the riser bolt holes... Hope this helps...
Attached Thumbnails Need help installing fairing-cymera_20130811_123215.jpg   Need help installing fairing-cymera_20130811_123327-1.jpg   Need help installing fairing-cymera_20130811_123358.jpg   Need help installing fairing-cymera_20130811_123449.jpg
Old Aug 11, 2013 | 05:14 PM
Northbound Southerner's Avatar
Does it mount to the riser bolts under the tree?
Old Aug 11, 2013 | 05:36 PM
605bob's Avatar
605bob
I don't believe the riser bolts penetrate through the bottom of the tree...?
Old Aug 11, 2013 | 05:41 PM
Ahh...You have a street bob with the integrated ones? That may be the deal...Did they say it would fit a Street bob specifically?
Old Aug 11, 2013 | 08:14 PM
605bob's Avatar
605bob
In the description of the eBay listing, yes rtated its compatible with my year and model. I've seen a few other street bobs with them as well on here. Can anybody that has one on their Bob chime in...? Thanks all!
Old Aug 12, 2013 | 06:34 AM
jpace024's Avatar
jpace024
Originally Posted by Vonswanko
Thats not going to work with the Street Bob, not without some fabrication. Thats supposed to fit bikes with top mount headlights. Super Glide, Sportsters...etc
+1 on this. Can't trust ebay sellers. The bike shown in the pics has a top mount light on narrowglide forks.
And here's the description from the link you provided: To fit 1973-UP Harley Sportster Dyna FX/XL with 39mm narrow Glide forks.
Old Aug 12, 2013 | 07:45 AM
HD Bobber's Avatar
HD Bobber
Here's pictures of the cowl, mounting bracket, hardware, and how I assume the bracket mounts to the cowl itself...
I think you bought the wrong one. The one you have is meant for sportster bikes with the top visor over the headlight. The metal bracket definitely does not bolt any where to your trees.
The one I have doesn't have that metal bracket. It just came with a plastic cup the fits over the back of the headlight then you put the visor in front. It sandwiches the headlight bucket and there are 5 screws.
Hope this helps...... eBay can be a ******.......
Old Aug 12, 2013 | 08:21 AM
HD Bobber's Avatar
HD Bobber
Here is the write up https://www.hdforums.com/forum/dyna-...-09-dynas.html
You need the night rod fairing, which works on 06+ dyna bobs
Few pics:
I had to space mine out about 1/2" by using some plastic spacers I got at ace. I placed themin between the screws of th fairing and the back cup bracket. This gave me a snug fit.
Old Aug 12, 2013 | 08:57 PM
605bob's Avatar
605bob
Thanks!
thewholehog
Feb 9, 2026 11:05 AM
Clown Shoes
Jul 31, 2016 03:16 PM
gnstalodz
Sep 27, 2015 02:36 PM
kainvamp
Mar 1, 2015 06:42 PM
gib3000
Oct 5, 2014 02:51 PM
