31mpg??
Old Aug 25, 2013 | 08:06 AM
Rampant's Avatar
Rampant
I'm pretty sure the tune is off. I didn't have it custom tuned, as all I have is a filter and and slipons. I grabbed a similar tune from the net but what I'm going to do as a baseline today is zero it out.
And I've gone through 2-3 tanks of gas and the milage has been consistently godaweful no matter how I ride. Given the meager power boost at best it's not worth it. I'm assuming that I've gone from not enough fuel to too much. My plan is all zeros, then assuming that puts things back to normal, try half the values that were in there.
Old Aug 25, 2013 | 09:10 AM
craig11dyna's Avatar
craig11dyna
Did you check your plugs? I suspect they will show it's running rich (dark color around the ceramic). They should be a tanish color.
Old Aug 25, 2013 | 12:40 PM
Junkster's Avatar
Junkster
I have a pcv with autotune and Stage two and get 38-42. I think your tune needs tweaked. Call fuelmoto if you have to.
Old Aug 25, 2013 | 03:06 PM
WG2011's Avatar
WG2011
Helped more than your comment in here. Plus he asked if this was typical I was proving the point it is not.
My point was you can have a decent tune and still get good mpg. If I was the op I would find a reputable tuner dyno tune it. You already have the money into the mods get it done right. The reason for the bad mpg had got to be the tune. Good luck
Originally Posted by Danielc409
^Well that really solves the OP's issue.
jjpish
May 12, 2012 08:23 PM
docsg
Apr 20, 2010 08:14 PM
harris48cars
Apr 12, 2010 09:49 PM
showlowzook
20
Mar 1, 2010 12:29 PM
TheSinistral
Jan 10, 2009 05:57 PM
