Clank and Bounce/Jump ?
Old 09-19-2013, 11:55 PM
Dyna7's Avatar
Dyna7
Dyna7 is offline
Default Clank and Bounce/Jump ?
Whats going on everyone,
I have researched this, looked through the manual, even had some friends look at it. Here is the problem....whenever I am cruising and i let off the throttle all the way and then hit the throttle it makes a metal on metal clank, any speed, i just let off all the way and get back on it and it clanks. any thoughts? S#!$ drives me crazy.
Second, it feels that when i hit bumps that my motor/tranny are jumping off of the damn bike.
Ok so the bike is a 2012 Dyna SB
Usually stuff, A/C, full exhaust, tuner
burly slammers
Any ideas ?
Old 09-20-2013, 12:41 AM
DeJavu's Avatar
DeJavu
DeJavu is offline
First thing, Check your primary drive, bet it's got too much slack.
Old 09-20-2013, 06:02 AM
Warp Factor's Avatar
Warp Factor
Warp Factor is offline
Might want to check the tightness of all your motor mount bolts too. Also check the mounts for signs of failure. Don't forget the one under the gas tank.
Old 09-20-2013, 12:54 PM
nevil's Avatar
nevil
nevil is offline
My first guess would be to check the fuel tank bolts, just put a wrench on and see. Then I would look at the motor mounts, especially the front.
Old 09-20-2013, 01:05 PM
parts eeter's Avatar
parts eeter
parts eeter is offline
Steer Stem Fall away, properly setup fork preload and oil, fuel tank bolts, and motor mount bolts. I also found that the stock drove compensator was crap and the SE version tightened it up as well.
All of these things will transform your bike into a solid ride.
Old 09-20-2013, 01:32 PM
Dyna7's Avatar
Dyna7
Dyna7 is offline
Ok extra info, it has 7000 miles and for about a week I had shocks that to short and I bottomed out everywhere.
Second do you really have to adjust the primary chain even with the auto adjuster?
Old 09-20-2013, 02:48 PM
bobnehoc's Avatar
bobnehoc
bobnehoc is offline
I had a clank on my SB a few years back and it was the tank bolts. They had loosened up and under acceleration or bumps in the road the tank would bounce a little and make that clank sound when it hit the backbone of the frame.
Old 09-20-2013, 03:33 PM
maddghost's Avatar
maddghost
maddghost is offline
Sounds like the front and rear motor mouns are a good place to check.
Old 09-20-2013, 04:25 PM
JonV's Avatar
JonV
JonV is offline
I just went through that with the front tank bolt....
prota72
07-19-2017 04:36 PM
Proline1969
05-29-2017 08:25 PM
Razorback Rob
08-28-2014 06:16 PM
Jackpoticorn
08-25-2014 02:46 PM
rjmdyna98
07-11-2012 12:21 AM
Quick Reply: Clank and Bounce/Jump ?
