Hey Mudpuddle
Old Mar 10, 2007 | 10:54 AM
Psycho's Avatar
Psycho
Default Hey Mudpuddle
How much fork oil did your tubes take???
Book says 26.6, then adjust to 4.4 inches. It took me two bottles, a full 32 ounces to get around 4.4 inches from top of tube to oil level.
Was your experience similar???
Old Mar 10, 2007 | 11:42 PM
mud's Avatar
mud
Default RE: Hey Mudpuddle
ORIGINAL: Psycho
Yeah psych, I do believe I remember it that way.
I was thinkin what the fork??
Seem to remember my service manual calling for more oil
in the "other dyna models".
I knew then that sumthin warnt right.
Went with the 4.4" method.
All seems fine.
So, I take you have the long forks on now.
mud
Old Mar 11, 2007 | 10:41 AM
Psycho's Avatar
Psycho
Long forks indeed, and as you said, all is well, so I suppose the oil level must have been correct.
My indy told me something yesterday, don't know if it's true or not, but makes sense. He said that the oil fill in ounces in the service manual is really the "wet" fill. He says that is the correct amount of oil for a drain and refill, whereas, in our case, it has been completely disassembled, so takes more oil, due to the fact that NONE is remaining in any little pockets, ect. Don't know about his analysis, but I filled it to the 4.4 anyhow, and it took right at 32 ounces.
What did you use for a seal driver?? I made one out of a piece of PVC. Worked great, and the plastic won't hurt anything.
Also, had a hell of a time getting the screw out of the bottom of the fork tube. Good impact was indispensable for this project.
Other than that, pretty damned simple. First tube probably took a couple hours, second tube, more like thirty minutes.
Bike rides and handles great. Pushed it pretty hard in the twisties yesterday, and had it to 105 without any poor handling exhibited. Not nearly as easy to drag the pegs now. Would really take some skill to get them on the asphalt in a parking lot. In the past I have routinely dragged the pegs all over parking lots, but not now.
Love the new stance. Feels more like some of the rides from my past.
Old Mar 11, 2007 | 01:51 PM
HOGRIDA_06's Avatar
HOGRIDA_06
Wow, the dealer told me 14 oz. per side. So I only bought 2 bottles, guess I better get two more. I got my lowers back from powder coat on friday and my seals yesterday. I was hoping to assemble the legs today but will have to wait until I can get more oil.
Old Mar 11, 2007 | 02:38 PM
clayman's Avatar
clayman
Mine took exactly what was suggested, just a question but because you lengthened your tubes would that account for more oil needed.
Old Mar 11, 2007 | 11:13 PM
mud's Avatar
mud
ORIGINAL: Psycho
Looks really good there psych. Nice job.
Is that the stock speedo??
"wet" fill theory makes sense to me.
Although I don't see where it really applies,
as HD has no provision for us to drain w/o dumping upside down.
Yep, I used 2" PVC as a driver. Just right.
And yeah my bottom pipes screws acted like they did not want to let go.
Had to get violent. Beat the shot out of em, relentlessly,
before they cried uncle andlet go.
Last time I had to hit anything that hard, smoke came outta their ***,
and I seen stars orbiting around their head.
How's your 95 build workin out??
What kinda pipes ya runnin there??
mud
Old Mar 11, 2007 | 11:50 PM
Psycho's Avatar
Psycho
It is the original speedo, but it is in a riser that came off of a wrecked sportster custom. The tach mount is a cnc machined aluminum custom job that a guy is making out in california. I bought it off of fleabay.
The pipes are python 2-1's, (V&H). They have already seen asphalt. My pegs used to be the feelers, with the new, higher stance in the front, the pipe is now the feeler. The 95 inch build is currently at approximately 91 hp, 94 torque. That is on a very conservative dyno, at 83 degrees. SAE 5 smoothing, correct tire pressure, no funky stuff. The real deal. My before run on the exact same dyno was 67/70, so I have achieved a quite considerable gain.
It is very rideable as well. A tad bit lumpy at low speeds in parking lots and such, due to the cams, but not bothersome at all. I'm quite happy with the bike and the build. Street friendly, but with lots of extra smiles. The thundermax system is hands down the best thing I've done for the way the bike runs. That system is the ****. The way it should have been from the factory.
Old Mar 12, 2007 | 02:11 AM
mud's Avatar
mud
Way out creative pysch.
Good work on the SuperGlide handlebar/instrument issue.
Hmmnh... looks good. Sound good??
Think they helped out on the dyno #s??
I've been leaning towards the DandD FatCats.
Gotta decide soon.
Refresh my memory, please.
Which cams did you go with??
What is thundermax??
Yeah, a healthy increase.
Who did your heads??
mud
ORIGINAL: Psycho
Old Mar 12, 2007 | 05:12 AM
just_bob's Avatar
just_bob
I just did the fork oil today on my wide glide conversion. I used 26.6 ounces, wide glide called for more ... but Im using bob fork tubes. Front end feels good? Maybe I'll compare left to right tubes, as I only drained and filled the one that required the new lower slider.
Take care,
-Dan
Old Mar 12, 2007 | 10:52 AM
Psycho's Avatar
Psycho
Popular opinion seems to hold that the 2 into 1's build the most power, to the tune of a 3 to 5 horsepower increase. I bought them at the advice of my dyno guy, who swears the he has personally confirmed that a good 2 into 1 was worth that increase on virtually every bike he had put them on. He is also the one that recommended the V&H product. He says they've been doing it longer than anybody, and somehow got it right. Like I said, I got those pipes based on common knowledge and his recommendation, so you will have to do your own research. As far as the sound, I really like it. It's a good deep rumble, no tinny crap, no banging or clanging, absolutely zero decel pop, just a good throaty growl down when decelerating from a pretty good twist. It sounds as mean deceling, as it does under throttle.
Those pipes are sold under the Python name, and I got them from AMERICAN-CLASSIC-MOTORS ebay store. They had the best price.
Went with the 211 cams. I did quite a bit of research, and eventually chose them based on opinions from my head man here in town. He runs a full performance shop, not just a head shop, and is very knowledgable. He did a heck of a job IMO. He has a flow bench, so it wasn't just a try this and see if it works deal. He flowed the heads before and after, and besides just porting and polishing, he balanced the flow of the heads as well. We saw huge increases on the bench. I think the head work cost me around 340 dollars. The heads were beyond crappy stock. In addition to being stuffed, they were terribly out of balance, and even the springs were all out of balance. He fixed that for me as well.
ThunderMax. In a nutshell, it is a complete replacement ECM which does NOT rely on air flow for it's information. Even slightly radical cams wreak absolute havoc on engine control systems which rely on air flow for engine information. This system solves that problem, as well as many others. I have seen absolutely nothing that can do what this system does, but you'll have to do your own reasearch, and make your own decisions about it. Read all about it here. http://www.thunder-max.com/Default.aspx
