Dyna steering woble
Old Oct 9, 2013 | 07:43 PM
nastynate42's Avatar
nastynate42
3rd Gear
Default Dyna steering woble
i have a 09 Dyna super glide custom. I recently added 12" apes and a fat boy head light. I once i get over 55-60 mph its like the handle bars are super sensitive. every little wind gust will give me a little wobble. Has anyone else experienced this after adding new bars and if so what is the fix? steering stabilizer?
Old Oct 9, 2013 | 07:53 PM
Ridewva's Avatar
Ridewva
Maybe your head bearings were border line loose? Try riding on a level or slight down hill around 50 mph in a higher gear. Release your grip on the bars as it slows down (keep your hands almost on them) and see if it starts to wobble. Usually most noticeable between 40 and 30 mph. If so they need snugged up.
Old Oct 9, 2013 | 08:04 PM
nastynate42
3rd Gear
can let go anytime i'm under 50 and tracks straight with no wobble. i thought the same thing. Bike has about 13,000 mikes
Old Oct 10, 2013 | 09:05 AM
Ridewva's Avatar
Ridewva
Not the steering bearings then. May just be the wind buffeting on your more extended arms initiating handlebar movement?
Old Oct 10, 2013 | 09:08 AM
203Cree's Avatar
203Cree
Stop death gripping your new bars. That's the problem and solution. Had the same issue when I went from low bars on my sporty to the mini's on the FXDB.
Old Oct 10, 2013 | 09:12 AM
Hogpro's Avatar
Hogpro
Former Sponsor
Tire pressure? Tire balance? How old is the tire? How much tread is left?
Old Oct 10, 2013 | 09:32 AM
SquidHead's Avatar
SquidHead
Had the same problem with my apes. Checked tire pressure, spoke torque, fall away...no change. I tried different risers, switched to poly bushings, and it got better, but it was still there. I finally got rid of my beloved apes, and the problem went away.
Like 203Cree said, death grip can cause it, too. In really gusty conditions, I'll start getting a similar, but less dramatic, wobble, and realize I'm death-grippping. Once I relax, everything smooths right out.
If you want to keep those apes, try relaxing your grip a little and see how it feels. Also, you can't go wrong by switching to poly bushings. They firm things up significantly over the stock rubber. Cheap and effective improvement.
Old Oct 10, 2013 | 09:47 AM
dyna rider's Avatar
dyna rider
Default Wobble
When I first bought my bike it had a wobble at speed, 50-60. Took it back to the dealer and they lowered the front tire pressure even though it was on the exact pressure the book called for. I was better after that but still there at higher speeds. I switched handle bars from the buck horns to Dyna Custom bars and it was a lot better. Had the neck bearing replaced and it helped a bit also. Bottom line is a steering dampener is really the only way to stop the high speed wobble. The wobble is caused by air hitting your chest and a death grip makes it worse, but loosening your grip when you're flying is a hard thing to do.
Old Oct 10, 2013 | 07:49 PM
zukeeper's Avatar
zukeeper
make sure you don't have them pushed to far forward ( over the forks), dyna's seem sensitive to that. I've seen some that wobbled with apes straight up
Old Oct 10, 2013 | 10:14 PM
HYPR's Avatar
HYPR
Exactly!
Looking at your photo it does look like your bars are "over center" and what this does is put your weight to far forward placing the bike out of balance and when you are at speed especially in the wind you tend to either lean hard forward or pull back but in either case both with a hard grip on the bars placing either pressure on the front end behind the center of the wheel and lightening the load on the rear tire when leaning forward or when leaning back lightening the front end.
Despite looking bitchen try pulling the bars back so that the grips are behind the steering head and take the bike out for a ride under the same conditions and see if there is a change.
Bob
