Remove starter from 98 Dyna Covertible
Old Nov 4, 2013 | 01:05 PM
mrgr8ness's Avatar
mrgr8ness
Default Remove starter from 98 Dyna Covertible
I haven't purchased the service manual yet for this bike. I'd like to know how to remove the starter. Can anyone share that section of the service manual, or guide me with a tutorial? I hope this isn't too hard a project.
Old Nov 5, 2013 | 10:17 AM
mrgr8ness's Avatar
mrgr8ness
Anyone? I can see 2 allen bolts at the top. I figure it can't be as simple as that
Old Nov 5, 2013 | 10:19 AM
Scudda's Avatar
Scudda
If it's anything like a softail...you will need to open up the primary also. I beleive there is a bolt in there.
Have you tried youtube?
Old Nov 5, 2013 | 10:35 AM
hvacgaspiping's Avatar
hvacgaspiping
Maybe this will work? 11713874-Harley_Davidson_Dyna_Models_Service_Manual_Repair_ 1998_Covertible.pdf
I took this out of context for my `09 Dyna and substituted your model, so it may not work, but give it a try anyway.
Old Nov 5, 2013 | 11:15 AM
JRK5892's Avatar
JRK5892
yep pull the primary cover, bend down the stay tab on the bolt, remove the bolt at the end of the starter, and then the gear, from there use some extended ball end allens to get to the allen bolts on the other side, undo the wires, and pull it out
Old Nov 5, 2013 | 04:31 PM
mrgr8ness's Avatar
mrgr8ness
Ugh, thanks guys. Was hoping it wasn't this much work. I dropped an exhaust nut, and I didn't see where it went. It didn't make it to the floor though. It had to have gone behind the primary, or under the starter. Tried compressed air, magnet, shaking and bouncing the bike-no help. I'd hate to not be able to find it, thought maybe getting under the starter would be a simpler job. Not sure if its worth it or not. Any advice?
Old Nov 5, 2013 | 04:39 PM
JRK5892's Avatar
JRK5892
screw it, get a different nut and leave it, will rattle its way loose bud
Old Nov 5, 2013 | 04:55 PM
mrgr8ness's Avatar
mrgr8ness
Yeah, got another nut already. Was going to get it on the lift tonight, give it one more look. I even have a bore scope, and couldn't see it. I don't think it can get into anything to cause trouble should it?
Old Nov 5, 2013 | 05:01 PM
bobnehoc's Avatar
bobnehoc
Just install the new nut and don't worry about it. It won't be able to get inside the motor and will most likely fall off while riding. Put some anti sieze on the new nut and torque it to specs while the motor is cold.
Old Nov 5, 2013 | 08:04 PM
mrgr8ness's Avatar
mrgr8ness
Thanks guys. Actually was swapping pipes, and the nut on the rear cylinder got a little wedged between the stud and the heat shield, then it broke free when not expected. Man looked a little more tonight, and really cant tell where that could have gone. Can actually see under the started a bit, and running the magnet should pick it up. I really cant see where it could have gotten stuck behind the primary. Also cant see where it could have gotten stuck next to the cylinder either. My garage floor is very clean, so I am positive that it didn't make it to the floor. Oh well, I will give it once last look on the lift, then put it all back together.
