Tail Lamp Problem Dyna FXDF
Old Nov 6, 2013 | 09:36 PM
FatBobK's Avatar
FatBobK
6th Gear
I'm having an issue with my tail lamp. I have the Tri Bar LED Tail Light. PT number 68546-09. It's been on my bike for about 4 years. It works fine when my bike isn't running, but after I start my bike it stops working. All of the other lamps are working fine turn signals, license plate light, headlights, etc. All of my fuses are good as well. Does anyone have any experience with this. Do I just need a new tail lamp, could it be my STT module, the wiring harness or even something else? The Tri Bar lamp is almost $300 so I don't want to go buy another one only to find that isn't the problem. Any suggestions would be greatly appreciated. Thank you very much.
Attached Thumbnails Tail Lamp Problem Dyna FXDF-image-91067144.jpg   Tail Lamp Problem Dyna FXDF-image-2212128423.jpg
Old Nov 6, 2013 | 10:42 PM
bdtaylor1979's Avatar
bdtaylor1979
Maybe something going on with the circuit that sends power to the light while the engine is running. I have no idea how to test that though.
Old Nov 6, 2013 | 10:44 PM
viciousvinny's Avatar
viciousvinny
Stage II
the original lamp has four prong holes but only three prongs at 1,2,and 4.move the fourth prong to the 3 position on the tri bar.
Old Nov 6, 2013 | 10:46 PM
viciousvinny
Stage II
check prongs on original taillight ,and tri bar.make sure there in same positions.
Old Nov 6, 2013 | 11:15 PM
FatBobK's Avatar
FatBobK
6th Gear
Thank you viciousvinny. I check the prongs.
Old Nov 7, 2013 | 07:37 AM
blueangel73's Avatar
blueangel73
Did that fix your issue?
Old Nov 7, 2013 | 08:08 AM
HD Pilot's Avatar
HD Pilot
I can't believe your Tri-bar has lasted 4 years! My mounting tabs cracked at 6 months, I installed a 90 degree aluminum fitting that holds it in place but it rattles like crazy at certain rpms. I would never spend another dollar on a new Tri-bar light, just trying to figure out what to replace it with.
Old Nov 7, 2013 | 08:09 AM
FatBobK's Avatar
FatBobK
6th Gear
I checked the prongs. They're all good. 1,2&3 are there and in alignment. I did see what Viciousvinny was talking about, there's no 4th prong. Should there be?
Old Nov 7, 2013 | 08:20 AM
FatBobK's Avatar
FatBobK
6th Gear
Alansummers you're right both of the things you mentioned were happening to mine as well, but in my opinion nothing out there looks as good as the TriBar so I can't go back now. This is what I did to 'fix' the rattling and the screw tabs. I put some of that thick Foam double stick tape underneath. Now it doesn't even budge. It's actually tough to get out now because it fits in so snug. My screw tabs broke as well. I fiberglassed some washers that were the same size to the unit and I haven't had an issue since. If I do buy a new one I'm going to do both of these things again.
Old Nov 7, 2013 | 10:05 AM
Hot6's Avatar
Hot6
If you still have your original tail lamp assembly. You could swap it back in. This would eliminate harness issues.
jasonbum
Nov 16, 2017 03:05 PM
JohnTM
Jun 13, 2014 01:56 PM
4sportster8
Electrical/Lighting/Alarm
Apr 24, 2014 05:16 PM
hbj77
Apr 23, 2014 02:00 AM
Spiro Drummer
Jul 28, 2011 12:18 AM
