06+ dyna detachable luggage rack?
Old Dec 2, 2013 | 01:41 AM
mirrmu's Avatar
mirrmu
Default 06+ dyna detachable luggage rack?
Hi,
Wondering if anybody has the width of the rack and the distance between the docking points on the detachable rack
I am interested to see if it fits on a 2010 wide glide?
Thanks
Mirrmu
Old Dec 2, 2013 | 02:17 AM
ynots's Avatar
ynots
2010 FXD: the inside dimension where the flush mount bolts pass thru the luggage rack and connect to the side plates and sissy bar is 7 1/4". I cant help you on the distance between the docking points
Old Dec 2, 2013 | 02:28 AM
mirrmu's Avatar
mirrmu
Hi,
Good onya ynots, but its the one like a motherwell rack that harley makes and it attaches to the docking points where sissy bar normally attaches
Part no. 53511-06, i know it says not compatible for 2010 wide glide but sometimes there is some anomalies
Thanks
Mirrmu
Old Dec 2, 2013 | 09:12 AM
bowmanvillejim's Avatar
bowmanvillejim
Originally Posted by mirrmu
Hi,
Thanks
Mirrmu
I have that rack for my O6 Super Glide. I will take measurements when I go home for lunch and post them here.
Old Dec 2, 2013 | 03:14 PM
slozomby's Avatar
slozomby
its the distance between the fender struts thats the issue not the distance between the docking points . the docking points on all 06+ dynas are the same distance.
if i remember correctly the '10 wide glides are a 1/2 inch wider than the streetbobs. so it should fit with some bending and stretching.
Old Dec 3, 2013 | 03:17 AM
mirrmu's Avatar
mirrmu
Hi,
Thanks for that, was at dealer the other day and parts guy reckon not much difference in width of fenders ie, strut to strut, but as usual they didnt have one in stock to pull out and try
Thanks
Mirrmu
Old Dec 3, 2013 | 08:14 AM
spdrcrjl's Avatar
spdrcrjl
for model years 06 and up. The center to center distance from the front mounting point to the rear mounting point is 10.375 inches.
gandydancer
Oct 5, 2015 09:10 PM
mirrmu
Nov 4, 2013 08:09 PM
kingomtn
Dec 21, 2011 01:41 AM
71FLH
Mar 6, 2010 10:24 AM
jcanrun
Oct 2, 2009 09:57 PM
