One more question. I read numerous threads on this and many of them ask if they should remove both seals, 1 seal or leave both on. I need to know what both seals means because when I received my bearing from Baker part # 189-56 it came with 1 black seal. I checked online at other stores and all of them picture the package as 1 bearing and 1 seal. In the installation instructions Baker pictures and only mentions 1 bearing and 1 seal. What is this other seal everybody is talking about?
Also... the Baker directions state to remove both snap rings. One internal and one external. My IPB only has 1 snap ring. It was behind the seal that I had to pry off. The other side doesn't have a snap ring unless I am missing something here. My service manual doesn't mention 2 snap rings either. I would have thought it would have both but I only see one.
Just take out the one snap ring in the case, install the Baker bearing in the case as you recieved it, and install the new Baker seal in the case.
Remove the Inner bearing sleeve from the trans shaft and assemble. Thats it.
I think they're talking about the seals which are integral to the Baker bearing, not the separate seal which goes on the transmission side.
There's been some discussion about whether it's better to remove one or both seals, when one isn't using an open primary, so the bearing is opened up to lubrication from the primary oil; or leave it sealed, in which case it would only be lubed by the original-fill grease.
I haven't seen this question resolved, so maybe it would be good to call Baker and get their latest info.
jgcable, how did the stock bearing look? I know you were concerned about riding it with the factory set up.
The bearing was perfect, the race was perfect, the compensator cup/rotor bolts were as tight as could be, the primary chain tensioner was perfect. The bike has 7800 miles on it and it has never given me a single instance of trouble.
It was a difficult decision to take it all apart but for piece of mind I did it. I also wanted to install a chrome inner primary anyway.
It was a difficult decision to take it all apart but for piece of mind I did it. .
I hear ya. My mother had an Explorer with those Firestone tires that blew out from time to time. As much as we told her the people who had the problem were way overloaded with under inflated tires she was scared to drive it until Ford replaced the tires. Once you get something in your head it's hard to get it out.
