Expected Power?
Old Dec 10, 2013 | 07:15 AM
hell hound's Avatar
hell hound
i have any 88" '06 dyna with pc3, andrews 37 and a bub 2 into 1 and it runs great you will love it. I put on the pipe the same time as the cams and it is a great combo, cant remember my numbers from the tune but you will like it
when i did my cams i put a 4 degree advance sprocket , my resoning was i was going to do the cams and then in a year or so boost it to 98" and do the heads and at that time i would take off the advance spocket, but i liked the way it ran so much i never did the other upgrades.
i did all the work myself because i am a cheap bastard. when i was in there i upgraded lifters, used SE adjustable pushrods and replaced the inner cam bearing with an upgraded version.
my dyna has many road trips under its belt and is also great to hotrod around on, it seems like a good reliable upgrade
Old Dec 11, 2013 | 08:12 PM
Puglia10's Avatar
Puglia10
sub'd for my 01 fxdx 88"…prefer torque and power coming in at lower RPMs
Old Dec 11, 2013 | 09:34 PM
ajmilberg's Avatar
ajmilberg
I'm also discussing with my local indy shop possibly doing the following: 98' big bore, rev performance cylinders, 0.01 gaskets, Andrews 37 cams, and power commander V. Anyone have experience with a similar set up?
gipper
Nov 16, 2023 11:53 AM
ajmilberg
Engine Mechanical Topics
37
Aug 26, 2014 09:23 PM
deerslayer1543
Jul 23, 2012 02:29 PM
trooper_355
Mar 6, 2011 08:05 PM
2NAHNTR
May 4, 2009 10:44 AM
