Chrome Powdercoat?
Old Dec 15, 2013 | 07:09 PM
nathanw's Avatar
nathanw
Default Chrome Powdercoat?
I'm wondering if anybody here has used chrome powder on their bike or anything else for that matter. If so, how does it look? How close is it to real chrome?
Seems like having parts dipped in real chrome is hugely expensive and if chrome powder looks good it would be a more affordable option.
Old Dec 15, 2013 | 09:37 PM
JonW's Avatar
JonW
Some of the OEM car manufacturers are using chrome powder coat or a similar process. It's not as smooth or as deep as real chrome. I would describe the finish as a little grainier than real chrome. But it's cheaper and more durable.
Old Dec 16, 2013 | 08:21 AM
nathanw's Avatar
nathanw
Do you know what manufacturers and which models they use it on? I'd like to go check it out in person.
Old Dec 16, 2013 | 08:26 AM
digitizer's Avatar
digitizer
I found this website, really kool, chrome in different colors,
it is: http://www.cosmic-chrome.com
Old Dec 16, 2013 | 11:02 AM
nathanw's Avatar
nathanw
Wow, that stuff looks great!
Old Dec 16, 2013 | 01:02 PM
Sport Chrome's Avatar
Sport Chrome
Former Sponsor
Default PVD coating
Hello,
I believe that the finish you are asking about is known as "PVD" which stands for "Physical Vapor Deposition"
It's a bit more complicated than traditional powder coating but when applied on the right surface it can give a look that is close to real chrome.
In order to have a result like traditional chrome, you will need to make sure your parts are smoothed and polished to a mirror finish prior to having the coating applied.
My company offered this service for about three years. It was used primarily for items made of magnesium that could not be traditionally electro plated. We stopped offering it a couple years ago because it is very expensive and the finish is inferior to a real chrome plated part.
Let me know if you have any questions I can help answer.
JR
Old Dec 16, 2013 | 05:57 PM
JRK5892's Avatar
JRK5892
our shop uses powder chrome pretty often, on a large scale it would look great but to be honest nothing can sub for real chrome... if it helps here are a bunch of pictures of parts we have coated in chrome powder coat for you
parts from a 1920's barber shop we restored
and chrome powder HAS to be cleared, sad cause this is what it looks like without the clear
Old Dec 17, 2013 | 04:27 PM
nathanw's Avatar
nathanw
It looks much more like chrome before the clear, it looks like silver paint after. What would happen if you didn't clear? I want to do my primary, trans, and timing cover, so would it flake off without the clear?
Old Dec 17, 2013 | 05:55 PM
JRK5892's Avatar
JRK5892
will not flake off, but will stain, yellow, and with some chemicals turn to goo. with clear it has a look of a dull rubbed alum. def not the same look as silver but also not chrome, your best bet is to find someone that has chrome covers and swap them or have yours coated black and trade
Old Dec 17, 2013 | 08:09 PM
nathanw's Avatar
nathanw
Thank you for the help.
