another traditional winter mod
Old Dec 25, 2013 | 07:58 PM
07 dyna man's Avatar
07 dyna man
Default another traditional winter mod
swapping out the 66t rear pulley with a 68t should be at aprox. 3.05 final gear ratio
Old Dec 25, 2013 | 08:59 PM
nevil's Avatar
nevil
Can't open the link, but that will make a difference you can feel.
Old Dec 26, 2013 | 08:32 PM
07 dyna man
Old Dec 26, 2013 | 08:34 PM
07 dyna man
that's better....... that harbor freight lift was the best 300 bucks I ever spent.....that's my brothers 05 fatboy with a 106 s$s stroker kit and deweys heads 120 tq. and 118 hp in the background
Old Dec 26, 2013 | 08:35 PM
Dynam1te's Avatar
Dynam1te
why not just go to 70t?
Old Dec 26, 2013 | 08:56 PM
07 dyna man
I would have to modify the belt guard bracket the 68 fits under the guard and with the 30 tooth front I didn't want to go that low on the gearing
Old Dec 28, 2013 | 06:13 PM
07 dyna man
perfect fit,,,,i picked this up at surdyke.com if anyone decides to do this part #40535-06 from a uropean dyna
Old Dec 28, 2013 | 06:45 PM
Ninety8NeonACR's Avatar
Ninety8NeonACR
It's a couple crisp $20 bills cheaper at New Castle HD, may have to keep this in mind for the future.
Old Dec 28, 2013 | 08:01 PM
HD Pilot's Avatar
HD Pilot
Yeah, I think I will do the 68T instead of the 70T also for the same reasons. Did you consider using ARP pulley bolts? I think they are about $30, not sure if they are worth it. Are you able to fix your speedo with the PC III? The PV makes it so easy. Sweet bike - you have some real nice mod choices
Old Dec 28, 2013 | 09:27 PM
07 dyna man
thanks allan,, unfortunatly no not with the pc111,,, no i reused the stock bolts i should have gotten new ones but i cleaned the threads on the bolts and hub and used plenty of blue loctite and couple of ft lbs tighter that spec ,,, i wonder if i purchase a pc5 from fuel moto they can convert my custom map to a pc5 map it would be worth it then i could recalibrate my speedo i need to update my photo im single now lol and have the solo seat on it now you can see almost the whole rear fender like yours
