13.5" shock with thunderheader
Old Dec 27, 2013 | 11:52 PM
monster715's Avatar
monster715
Default 13.5" shock with thunderheader
What's up guys just want to make sure I'm not going to run into clearance issues after spending $650. I want to put 13.5" rear shocks on my bike and I'm wondering if anybody else is running them with a thunderheader without clearance issues with the bracket. Also I'm torn between the ricors and the works shocks. Any opinions? Thank you in advance
Old Dec 28, 2013 | 07:02 AM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
One way to find out, slap em on there. you obviously don't work for the gubbment with only three posts in three and a half years. Good luck. Ohh nice paint job too looks good.
Old Dec 28, 2013 | 11:50 AM
monster715's Avatar
monster715
Thank you on the paint. Yea I don't ever post I usually just use the forum for info that I can find that's already been discussed
Old Dec 28, 2013 | 12:14 PM
SLV's Avatar
SLV
Check out the Thug Style/Club Style thread. Lots of T-Headers and tall shocks. If you post your question there, you'll get a lot of answers.
I'd like to hear the Ricor/Works assessment too.
Old Dec 28, 2013 | 02:32 PM
fordaith's Avatar
fordaith
You will have to shave the bolts on the muffler of the T-header. I had issues with mine rubbing the swing arm with the 13.75" Works I have on mine. As far as the exhaust and the pipes making contact....you should be fine.
Old Dec 28, 2013 | 02:33 PM
monster715's Avatar
monster715
Right on slv thanks for the pointer I'll post this there.
Old Dec 28, 2013 | 02:41 PM
monster715's Avatar
monster715
This is what I was concerned with. So after you shaved the bolts down you haven't had any issues? I wasn't sure about how much side to side movement there was with the swing arm ( obviously not much ). How do you like the works shocks? I like that they are small in diameter, I'm going to buy the retro t sport bags and don't want them to rub and tear up the bag
Old Dec 28, 2013 | 04:40 PM
fordaith's Avatar
fordaith
Haven't had a single issue. There's not much lateral movement on the swing arm that you have to be concerned with because both the swing arm and pipe move together due to being mounted on the transmission case. I cut about 3/8th of an inch off and put some Loctite, not an issue. The easiest thing to check your clearance is to get the bike off the ground if you have the TH on the bike already, and drop the rear wheel down to see where your swing arm makes contact. Mark the bolts, then cut/shave accordingly.
As far as the shocks go, I love 'em. I am running the LeatherPros repro T-sport bags as well, and have zero clearance/rubbing issues.
Old Dec 28, 2013 | 05:04 PM
monster715's Avatar
monster715
Right on thanks for the info I was pretty sure that was going to be the only issue I just wanted to make sure before I spent $650
mikerocklin
Powdercoat & Paint
Nov 20, 2018 10:10 PM
PumpinIron
Sep 1, 2014 02:29 PM
monster715
Jan 16, 2014 12:44 AM
TheMurf
Sep 6, 2011 08:55 PM
HollywoodHillsHD
May 27, 2008 07:48 PM
