Dyna Shifter squeak
Old Aug 30, 2005 | 03:36 PM
Headwolf's Avatar
Headwolf
Default Dyna Shifter squeak
Hello
Simple question for you When I move the shift lever on my 05 Dyna Superglide Custom I get a high pitched squeak It doesn't have to move much and not even have to change gears It sounds like the shaft is rubbing on the case. How do I fix that I could spray some lube in there but that would only temporarily fix it if it is rubbing Could this cause unnecessary wear on the shaft and/or case Is something out of alignment? Could this be an indication of something more serious? Only 400 some mile on it. Guess I can wait until I take it back for the 1k checkup. Any advice welcome
Old Aug 30, 2005 | 07:13 PM
HDF Tech's Avatar
HDF Tech
Default RE: Dyna Shifter squeak
It's probably the shaft where the foot shifter pivots, you can remove the shift peg arm and slide out the shaft to grease it. Just try to measure where it is as far as height off the floor so you can get it back in the same position on the spline.
Old Sep 2, 2005 | 02:38 PM
jaxdwg's Avatar
jaxdwg
Yep; TC is right, just lube it--jack
Sammi
Aug 19, 2015 04:32 PM
128auto
May 7, 2013 09:32 PM
retiredin04
Aug 2, 2010 08:58 PM
bayouboy52
Apr 21, 2010 09:35 PM
dchoran
Oct 13, 2007 03:47 PM
