HELP on lifts???????
Old Mar 18, 2007 | 01:53 PM
makoshark333's Avatar
makoshark333
Default HELP on lifts???????
Okay, I have read more posts on bike lifts. Everybody says Sears is the best bang for the buck. I just went to the web site and seen they are $69.00 on sale. BUT......read the reveiws and 7 out of 8 says it SUCKS!!!! The thing breaks and no replacement parts for cylinder and seals. I beleive I would need the adaptor for use on an 06 DYNA. My back doesn't like me hunched over doing spokes anymore. What's the best way to go??? MAKO
Old Mar 18, 2007 | 03:18 PM
ckgdrums's Avatar
ckgdrums
Default RE: HELP on lifts???????
Stay away from the Sears lifts. Check this one out: www.jsjacks.com
Old Mar 18, 2007 | 05:11 PM
man4mopar's Avatar
man4mopar
I purchased the Sears red jack. Haven't had it long enough to recomend or coment on it's reliability. I have had my 06 Dyna WG lifted on it and was very stable. I used 2x4's as spacers, I will however be buying the Harley adapters. The construction of the lift appears fine. As for replacement parts for the bottleneck jack, hmm never thought of it or cared, it is a bottle neck jack they are cheap and readily available everywhere.
Old Mar 18, 2007 | 05:19 PM
streetboob's Avatar
streetboob
I got mine at Wal Mart for $79 and it works great. I've had it for 2 years now and use it all the time. Never had an issue with it. Don't remember the brand name though.
Old Mar 18, 2007 | 05:53 PM
jmbear328's Avatar
jmbear328
I bought mine at Harbor Freight. I got the yellow one that they carry. Its labled as an ATV lift, it works great. Really sturdy and was a lil cheaper than the lil red one at sears and alot sturdier and I think it was $62.
John
Old Mar 18, 2007 | 06:07 PM
HOGRIDA_06's Avatar
HOGRIDA_06
My bike has been sitting up on my red Sears jack for the last two months, no problems and very sturdy(even w/ the front end removed).
Old Mar 18, 2007 | 09:14 PM
soup48's Avatar
soup48
I bought my jack from Northern Hydraulics. It can lift my wife's '04 FXD and my '06 FXDCI. It is also set to were you can adjust it to the bike by the sides.
Old Mar 18, 2007 | 09:23 PM
SPECIAL ED's Avatar
SPECIAL ED
I have the red lift from Sears and it works fine.I don't see where I would need any type of adapter.It's a little tippy, ie you can't sit on it while it's jacked up if you don't use the included ratchet straps to secure it, but for cleaning the spokes or changing oil it's fine.
Old Mar 18, 2007 | 10:13 PM
oldsporty1's Avatar
oldsporty1
I have had the red one from sears for about 2years, used on my Sportster and StreetBob never had a problem.
Old Mar 20, 2007 | 07:08 AM
Timmer's Avatar
Timmer
Mako, my Red Sears jack works great. I've never had a problem with it. I would imagine if you hadto use it everyday, you would have to invest in a higher quailty jack but for cleaning and routine maintenance, it works fine. I use blocks to ride up on for clearance and use the adaptors also.
I do use the straps now to secure it down. It's not worth it to me of my scoot falling off the jack. Tim
