How do you clean spokes and hubs?
Old Feb 25, 2014 | 09:40 PM
LAFO's Avatar
LAFO
Aren't those options to abrasive and scratch the chrome on the spokes? Or are the spokes stainless? Haven't actually analyzed that.
Old Feb 26, 2014 | 09:20 AM
Guest
Guest
Posts: n/a
I used the bathroom cleaner, Kaboom. It sprays on blue then turns white and you'll see the dirt lift up in the foam. Then rinse, then use a towel to wipe away anthing left over, they will shine like never before!
Old Feb 26, 2014 | 10:43 AM
tomt's Avatar
tomt
To get down into the hub area I use these. You can use them to detail the whole bike.
http://www.pimpstixxx.com/
Old Feb 26, 2014 | 10:56 AM
"HI"'s Avatar
"HI"
I use a swifer duster, works great!!!
Deucedog's Avatar
Deucedog
All good ideas. I'm not sure that I'd be comfortable using something abrasive but hey, if it works why not.
I cut a micro fiber cloth into 2" strips, add a little polish, and wrap a strip around the spoke and use a 'see saw' motion to clean/polish the spoke.
I tie one of the strips around the center hub of the wheel and go for a short ride.
The one thing that helps keep the spokes clean is to keep them clean all the time.
The biggest thing I've done to alleviate the brake dust problem is that I switched to Lyndall Z brake pads. I get close to zero brake dust and they work better in wet weather.
Old Feb 26, 2014 | 11:13 AM
Guest
Guest
Posts: n/a
Thank you for your service, it was well appreciated by those who do.
Old Feb 26, 2014 | 11:22 AM
Deucedog's Avatar
Deucedog
Thanks Illusion.
JRK5892
Powdercoat & Paint
Apr 7, 2012 07:12 AM
Marty31
Mar 15, 2012 12:26 PM
SoftTailTim71
Sep 1, 2008 10:28 AM
vegashd
May 17, 2006 03:31 PM
