2011 WG Rust!
Old Feb 23, 2014 | 07:47 AM
Yankeedave's Avatar
Yankeedave
6th Gear
Default 2011 WG Rust!
Hi all. Ive got a 2011 Dyna WG which I keep in very clean condition all year round. I took the seat off today to have a look at raising the tank for a good cleaning of rocker covers. I then notice a bit of surface rust where the two pieces of sheet matal meet between the battery box and the shock mount. (Im not sure if the description makes sense)
Im still under warranty with the dealer so I am going to call them in the morning.
Has anyone else had this issue? Ill take pics if needed for a better idea.
Thanks
Old Feb 23, 2014 | 07:53 AM
UppercaseJC's Avatar
UppercaseJC
Did something wear the paint off at this spot.
Old Feb 23, 2014 | 08:14 AM
Yankeedave's Avatar
Yankeedave
6th Gear
No Upper, there is nothing there but space... I dont get how this could hae happened. Unless it was just bad paintwork.
Old Feb 23, 2014 | 09:30 AM
Foxster's Avatar
Foxster
I hope you haven't been using a Harley during a British winter?
Not sure just what they are designed for but they are really, really intolerant of British winters and especially road salt. Leave a Harley for a week with a bit of salt on it and it will have started to rot.
I haven't been out on mine since Christmas and it was spotless when I put it away, even so there was oxidation in loads of places and rust spots in the all the corner and joint places where Harley can't be arsed to put more a dusting of paint.
One thing to check on yours is whether you have a big hole in the rear mudguard behind the spot you are describing. My Fat Bob did. It siphons road water straight into that area and can really mess with the electrics and metal-work there. Filled mine with expanding setting foam but I'd bet there's a neater solution.
For your spot that doesn't usually show I'd clean up the rust with a wire brush and wire wool then brush it with Hammerite primer then paint. Will never trouble you again.
Old Feb 23, 2014 | 09:36 AM
skinman13's Avatar
skinman13
As a lead-acid battery charges, it gives off corrosive gasses. Any bare metal around the area will corrode quickly in a damp climate. It is difficult to stop corrosion once it starts without stripping, etching, priming, and repainting. For visible exterior areas, this is the only solution for me. For interior spot treatments like you are describing, I have had good success using Chemprime Rust Inhibitor, which essentially changes surface rust to primer then spot paint. If you can get any par-al-ketone or CRC Soft Seal products over there, they are excellent for sealing out moisture and do a real good job on electrical terminals as well. These are not permanent and can be cleaned and reapplied as needed and are very popular with civil and military aircraft applications.
Old Feb 23, 2014 | 09:43 AM
Foxster's Avatar
Foxster
Aren't they sealed gel mat batteries now?
Old Feb 23, 2014 | 09:49 AM
skinman13's Avatar
skinman13
Sealed means that you do not service them...but they also still vent and emanate gasses when charging, even trickle charging...it is the nature of the beast.
Old Feb 23, 2014 | 12:21 PM
Yankeedave's Avatar
Yankeedave
6th Gear
Hey Fox. I have not been on my bike sense beginning of november. Its stored in a dry heated garage and is heated to acf for the winter. Also to boot she sits on carpet as well. So it cant be from storage. And its never really had road salt on it. Im going to speak to HD tomorrow. This should not have happened. The bike only had 700 miles In April.
Old Feb 23, 2014 | 06:36 PM
Foxster's Avatar
Foxster
There's been a few folks had chunks of paint peeling off newer Harleys. Seems that either they didn't bother priming or they primed over rusty metal. Seen some truly awful mudguards a year old where the paint has fallen off in 6" sheets leaving bare rusty metal.
On my 4 year old bike I've had paint peeling off the frame, the sides of the front mudguard, under the seat. Plus loads of corrosion in odd spots all over the bike.
Definitely been some pretty crappy painting going on at HD recently.
Hopefully you get it sorted under warranty.
Old Feb 24, 2014 | 01:32 AM
Aires59's Avatar
Aires59
I put a new back tyre on my 2011 WG last week, the inside of the wheel rim only had a very thin spray of paint over it and there was a line of rust round the rim by the spoke protecter. Perhaps HD are having problems with build quality.
