Custom tail light??
Old Mar 13, 2014 | 10:59 PM
Repoguy's Avatar
Repoguy
Default Custom tail light??
so I really wanna take off my signals so I can run bags, I was wondering if anyone knew if this can also do signals or knows of a kit like it that will do stop and turn lights.. I think it would look slick like this without the turn sigs mounted... http://www.harley-davidson.com/store...der-edge-light
sorry for the crappy typing, smashed my fingers at work and had blood running out from under the nails.. so typing kinda sucks
Old Mar 13, 2014 | 11:18 PM
jdub099's Avatar
jdub099
There's this:
http://www.westendmotorsports.com/ea...e-p-21049.html
Old Mar 14, 2014 | 12:02 AM
Repoguy's Avatar
Repoguy
ive seen that, I wanna just remove the signals completely and have the rear strip in the fender do it all s/t/t .. I got a bracket to move the plate back in the stock form...
Old Mar 14, 2014 | 12:13 AM
jdub099's Avatar
jdub099
Well I don't think that strip does anything but tail and brake. You may be able to take it apart and split the lights into two circuits so there's a left and a right. But I don't think there's any easy, off the shelf solution here.
Old Mar 14, 2014 | 12:39 AM
slozomby's Avatar
slozomby
if your going for the super minimal look
http://www.customdynamics.com/integr...light_bars.htm
and/or
http://www.customdynamics.com/illumi...ED_Plate_Frame
depending on the bags you opt for you could possibly string some lights onto the bags for turn. and use the brake light you linked.
personally i like the folks behind me to see when i hit the brakes.
Old Mar 14, 2014 | 07:56 AM
MatFink's Avatar
MatFink
something like this maybe?
ebay cheapie
Old Mar 14, 2014 | 08:04 AM
jdub099's Avatar
jdub099
Problem is that with the run/stop/turn function, if your tail/brake is separate from your signals, the brake light is going to blink with the signals. There is only one wire (per side of course) for the brake/signals, the purple wire.
If you wanted something like the above to work you'd need to be more creative with the wiring, you'd need to tap into the brake light before the stop/turn module.
Old Mar 14, 2014 | 02:34 PM
Repoguy's Avatar
Repoguy
damn that sounds a little out of my comfort level.. I was hoping something like the Harley one was available..
Old Mar 14, 2014 | 03:13 PM
spyderwebb's Avatar
spyderwebb
Check out Decision Dynamics, they have some good options, good advise, and fairly easy installs.
EDIT- Correction: "Custom Dynamic:
Old Mar 14, 2014 | 03:20 PM
jdub099's Avatar
jdub099
You have a link for that? Google pulls up a whole lotta nothin'
EDIT: Figured out from your signature you meant CUSTOM Dynamics.
