Front end clunk?
Old May 9, 2014 | 08:22 PM
bikerider3's Avatar
bikerider3
Stage III
Default Switchback front end noise
Originally Posted by chainbreaker
I had a clunk in the front of my 09 FXDC that drove me crazy. Found the front tank mount bold barely loose, but it was enough to clunk loud. Good luck.
I've had a clunk in the front of my Switchback on rough roads for a while. I'll check the front tank mount bolt. Thanks for the tip.
Old Aug 6, 2014 | 06:55 PM
Stuntgrunt's Avatar
Stuntgrunt
Originally Posted by jpicht
Thanks for the compliment. By the way, there's a facebook page for 35th Anniversary owners: https://www.facebook.com/groups/196393540511025/, check it out.
Tried joining that fb page weeks ago but no response to the request or PM. Maybe I smell
Old Aug 6, 2014 | 08:40 PM
hAkron's Avatar
hAkron
You need this: http://www.harley-davidson.com/en_US...ts/-J04469.pdf
There was a problem with the 2006 dynas and the steering head nut torque. Also, there is a washer with an index tab that keeps the steering head nut in place. The original washer part was changed to a stronger washer because if you try to torque the steering head nut down the the updated 70-80 ft-lbs, the index tab would typically sheer off.
Not the ONLY cause of 2006 clunk, but a common one.
Steel Steed
Jul 8, 2012 06:05 AM
supercrewser
Aug 17, 2010 08:28 AM
smithmx47
Oct 25, 2009 07:36 AM
SlimShady
Screamin Eagle CVO Models
Oct 1, 2009 08:17 AM
ss377
Jun 4, 2007 01:00 AM
