Front end clunk?
Old Mar 17, 2014 | 02:25 AM
JayDRod's Avatar
JayDRod
No "clunk" here... solid and smooth even hitting a hard pot hole (as long as you are not bottoming out). I had experienced a "cluck" feel though and found I could feel it somewhat by backing down a hill and hitting the front brakes (only). It turned out to be the head bearings. Important to check those to be sure they are still good and have the proper amount of tension on them I think. Also, make sure your pinch bolts that hold you axle into the bottom of the right fork (in my bike anyway) are in place and properly torqued (with thread locker). That would also account for a "clunk" (a very dangerous clunk as you could lose or cause your front wheel to lock up).
Old Mar 17, 2014 | 06:57 AM
skinman13's Avatar
skinman13
I was also hearing/feeling a clunk on rough roads and hard braking...tried tightening the tank bolts, retorqued the header pipe nuts, replaced the riser bushings and went over everything up front with a fastener on it...still clunked. Finally realized that the tubes were bottoming out. Rebuilt the tubes with an aftermarket kit only to have both seals blow out within 5 miles and did it again with OEM parts, added 3/4 inch spacers, and put in 10W fork oil. No more clunking, no more bottoming out...Still a little too much sag so I am looking at intiminators.
Old Mar 17, 2014 | 09:36 AM
jpicht's Avatar
jpicht
Originally Posted by Billsbuffalo
Thanks for the info, BTW your '35 looks a beauty.
Thanks for the compliment. By the way, there's a facebook page for 35th Anniversary owners: https://www.facebook.com/groups/196393540511025/, check it out.
Here are some better pics of "Ethel":
Old Mar 17, 2014 | 02:21 PM
Black Bart's Avatar
Black Bart
You could also check the lockwasher located under the stem nut of the upper clamp/triple tree. There was a service bulletin issued on that for 2006 models.
Old Mar 17, 2014 | 03:38 PM
SquidHead's Avatar
SquidHead
Do it, you will be very happy with them, especially with Amsoil #10.
Old Mar 17, 2014 | 06:33 PM
aces&8s's Avatar
aces&8s
Steering Stem nut and or washer. some just need tightened.
Old Mar 17, 2014 | 06:43 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
If the tank bolt didn't fix the clunk try this. Loosen the lower triple tree pinch bolts, retorque the steering stem bolt, then retighten the lower pinch bolts. May have to hit the lower with a plastic/rubber mallet to loosen the tubes in the lower tree.
Old Mar 17, 2014 | 08:16 PM
El Pescador's Avatar
El Pescador
Yep, had the same, it was the rear tank bolt for me.
Old Mar 20, 2014 | 06:46 PM
missedem's Avatar
missedem
If a simple fix was not in the cards put in some new neck bearings. Mine were dry from the factory and I had that problem. New bearings , mucho grease, no clunk (got rid of my squirrly front end as well).
Old Mar 20, 2014 | 08:40 PM
fattybob's Avatar
fattybob
The clunk I had on my 09 fat bob was a loose steering stem. Adjusted the fall-away per the manual and clunk was gone.
